Hurst Ramrod shifter installed in A body.
Manual Transmission & Clutch Discussions
  1. cpearce
    cpearce Well-Known Member
    609
    230
    Sep 1, 2010
    Edson
    Local Time:
    1:23 PM
    I have complete A body RamRod shifter I did not use, and will not be using. Another member of FABO is interested in purchasing the shifter from me. Understandably, he is looking for information about modification required to install in an A body. As I did not have installed I cant help him with this info. Can anyone help us with information or photos? Thanks.
  2. Brad4406
    Brad4406 FABO Gold Member FABO Gold Member
    2,010
    229
    Apr 20, 2008
    Lebanon, OH
    Local Time:
    2:23 PM
    If it is an A-body version, the only modification required is possibly opening the shifter hole a bit, assuming it's going into a 4-speed car. Can't access my pics now, but that's the only modification that was necessary on my '71 Duster.
    Here's a link, but the pictures aren't of any value.
  3. dicksmidlac
    dicksmidlac Well-Known Member
    60
    110
    Jul 6, 2005
    Thunder Bay Ont
    Local Time:
    1:23 PM
    I posted the pics in the link.Oops!Anyways here's a few of mine.
    • Like Like x 1
    • dicksmidlac
      60
      110
      Jul 6, 2005
      Thunder Bay Ont
      Local Time:
      1:23 PM
      If you need better pics I can take more up close after work.
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
      15,247
      4365
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      1:23 PM
      And then you have the big shift boot to deal with, that doesn't fit on the hump.
      But if it's a race car, that's no biggie
    • mcode
      mcode Well-Known Member
      207
      16
      Jul 6, 2009
      Local Time:
      1:23 PM
      If it has a bench seat, the cushion will have to be notched.
    • cpearce
      609
      230
      Sep 1, 2010
      Edson
      Local Time:
      1:23 PM
    • dicksmidlac
      60
      110
      Jul 6, 2005
      Thunder Bay Ont
      Local Time:
      1:23 PM
      A little fab work at the back also,where you see a small round piece added.Fairly easy
    • AJ/FormS
      15,247
      4365
      Jan 19, 2014
      Local Time:
      1:23 PM
      If you're handy with metal, you can build yourself a new mounting bracket to raise the shifter up and move it forward. This will angle the stick forward closer to the floor; so eventually you will run out of shift travel. But it will center the stick better.
      On one car I had, I just did that and centered the stick where I wanted it. Then shortened the rods .
      On another car I moved the shifter back between the buckets, and built new rods. No more reaching.
    • 19DART66
      19DART66 Well-Known Member
      186
      27
      Nov 19, 2008
      Ballston Lake NY
      Local Time:
      1:23 PM
      Pic of my Ram Rod shifter on the Jerico DR4W. With homemade bracket and linkage to put the shifter dead center in original hole in floor and one of shifter in the interior. Had this shifter on a Liberty prepped 833 with homemade bracket to center it in factory hole too.
      • Like Like x 3
      • 19DART66
        186
        27
        Nov 19, 2008
        Ballston Lake NY
        Local Time:
        1:23 PM
        Interior pic, didn't come out in first post.
        • Like Like x 2
        • cpearce
          609
          230
          Sep 1, 2010
          Edson
          Local Time:
          1:23 PM
          I like that, I might have to test my fabrication skills and see if I can manufacture a bracket to mount shifter in factory hole. I was going to sell the shifter because I didnt want to modify my original floor, after seeing this I am reconsidering.
        • dicksmidlac
          60
          110
          Jul 6, 2005
          Thunder Bay Ont
          Local Time:
          1:23 PM
          If you center it you might be reaching for it,being a straight short shifter.Just something to think about.The floor mods are so minor you can easily put it back to stock.I didn't want to cut my floor either but I'm glad I did now.The rods are pretty tight in there and definitely didn't want to modify those.
