1. Buford19
    Buford19 Well-Known Member
    368
    232
    May 22, 2014
    Kitimat b.c.
    Local Time:
    6:56 AM
    AA84E269-7966-421F-BD1C-8715B8061ACF.jpeg Has anyone used one of these wilwood master cylinder for a hydraulic throw out bearing on a A body mopar?If so where did you locate it on the firewall? Was thinking of installing it where the mechanical linkage normally goes through the fire wall. This seems to be a long way from the clutch pedal, but guess it might work.
  2. LJ67barracuda340
    LJ67barracuda340 Well-Known Member
    583
    397
    Mar 5, 2012
    Ontario, Canada
    Local Time:
    9:56 AM
    I mounted mine where the linkage would normally live. but you'll have to make room in the inner fender for it's length for R&R.
    • Like Like x 3
    • jbc426
      jbc426 Well-Known Member
      2,054
      879
      May 30, 2007
      West Coast
      Local Time:
      6:56 AM
      Nice work. Does your entire front clip come off from the car, or how did you get that last shot? Did that dimple affect your access to the upper control arm eccentric nut, or do you have an aftermarket front suspension?
    • Buford19
      368
      232
      May 22, 2014
      Kitimat b.c.
      Local Time:
      6:56 AM
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      51,552
      20550
      Oct 14, 2010
      Idaho
      Local Time:
      6:56 AM
      Somebody, somewhere on here came up with an experimental bracket that mounted inline with the original pushrod hole in the firewall, and I don't think the cylinder they had required fender mods, but I might "be forgettin"
    • LJ67barracuda340
      583
      397
      Mar 5, 2012
      Ontario, Canada
      Local Time:
      9:56 AM
      My front clip is mounted as stock,, front suspension is stock except for tubular uppers,, Access to control arm bolt is no problem except it must go in from the left. I cut the hole and welded a hammered out, cupped replacement piece to give clearance for the master with room for removal if needed..last shot is on the welding bench before the inner fender was installed.
      • Thanks! Thanks! x 1
      • Buford19
        368
        232
        May 22, 2014
        Kitimat b.c.
        Local Time:
        6:56 AM
        Just installed this wilwood clutch master cylinder, with no issues. Didn’t have too make any additional room, it fit with about 1/4 inch of room between it and the inner fender. This was a nice surprise. Going to make a larger backing plate for more support on the inner firewall. Also will have to make a longer adjustable push rod.
      • dodgedifferent2
        dodgedifferent2 Well-Known Member
        2,703
        524
        Aug 8, 2008
        southwestern, Ontario
        Local Time:
        8:56 AM
        I also had to make a longer pushrod as well. Otherwise the peddle would of been lower than the brake pedal
      • LJ67barracuda340
        583
        397
        Mar 5, 2012
        Ontario, Canada
        Local Time:
        9:56 AM
        My peddles ended up even without extending the push rod. Do you think you'll be able to remove the master down the road if needed. That's the reason I made the clearance. I guess our adapter mounts are different lengths.
      • Buford19
        368
        232
        May 22, 2014
        Kitimat b.c.
        Local Time:
        6:56 AM
        Where did you get your push rod set up, or did you make yours? The one that came with my kit, is not going to work.
      • 67Dart273
        51,552
        20550
        Oct 14, 2010
        Idaho
        Local Time:
        6:56 AM
        What specific kit did you get? Do you know that it has enough stroke, etc?
      • Buford19
        368
        232
        May 22, 2014
        Kitimat b.c.
        Local Time:
        6:56 AM
        Got my kit from sst, says it’s for a body mopar. Think it’s just a universal kit.
      • LJ67barracuda340
        583
        397
        Mar 5, 2012
        Ontario, Canada
        Local Time:
        9:56 AM
        My peddles and hydraulics came from Keisler, I cant find a pic of the specific kit but you can see here how long the master push rod is, kinda.
      • mopardude318
        mopardude318 Well-Known Member
        10,187
        1807
        Jan 7, 2005
        Gilroy, Ca
        Local Time:
        6:56 AM
        what trans is that?
      • pishta
        pishta I know I'm right....
        21,413
        10790
        Oct 13, 2004
        Tustin, CA
        Local Time:
        6:56 AM
        buddy had a Tilton T/O setup on his 833 in a 65 A. Had to reinforce the firewall for the cylinder. We used a trans bell to block support from firewall to shock tower.
      • LJ67barracuda340
        583
        397
        Mar 5, 2012
        Ontario, Canada
        Local Time:
        9:56 AM
        • Buford19
          368
          232
          May 22, 2014
          Kitimat b.c.
          Local Time:
          6:56 AM
          Thanks for the picture, I am going to pick a longer threaded section. Pretty sure it will all workout.
        • dano
          dano Evil Handy Man
          4,073
          1913
          Aug 22, 2005
          Gresham, Oregon
          Local Time:
          6:56 AM
          Do you have a part number for this? I can't find it.
        • Buford19
          368
          232
          May 22, 2014
          Kitimat b.c.
          Local Time:
          6:56 AM
          Will look for it tonight.
          • LJ67barracuda340
            583
            397
            Mar 5, 2012
            Ontario, Canada
            Local Time:
            9:56 AM
            look up hyd clutch kit at Silver Sport or American Powertrain.
            • Buford19
              368
              232
              May 22, 2014
              Kitimat b.c.
              Local Time:
              6:56 AM
              Pretty sure it is this slave unit. Summit racing part number 260-6089. Mine says 0750 on the side of it. That’s the bore size on this unit. Not sure where the adapter that’s mounts to the firewall. Give silver sport transmission a call, they will point you in the right direction. Good guys over there.
