I am Sooooo Confused over Paint
Mopar Body and Trim
  1. dartfreak75
    dartfreak75 Restore it, Dont part it! FABO Gold Member
    10,834
    8457
    Aug 10, 2011
    Virginia
    Local Time:
    8:22 AM
    I saw a video where a guy was working on a customer's truck and the truck when new was coated in por 15 or some other undercoating products and from a distance it looked like it was doing its job but he discovered that it was rusting under the coating bad! Like the floors where gone. Iirc he was replacing brake lines and the brackets where even rusted in half the whole truck was rotten because of this coating it was just holding in the moisture under the coating. And this was like a 10 year old truck (farily new to me) and I was a lost cause.
    • Like Like x 1
    • dartfreak75
      10,834
      8457
      Aug 10, 2011
      Virginia
      Local Time:
      8:22 AM
      I used rustoleum on my floors both inside and put, trunk, gas tank, inside of the fenders and all my suspension parts . Works pretty good for a driver quality rig.
      • Like Like x 1
      • jos51700
        jos51700 Green Bearing thread connoisseur
        5,969
        2738
        May 24, 2009
        Bel-Ray
        Local Time:
        7:22 AM
        Ok so now we hate POR15, is that right?
        • Like Like x 1
        • dartfreak75
          10,834
          8457
          Aug 10, 2011
          Virginia
          Local Time:
          8:22 AM
          Iv never used it but I don't think i would.
          • Agree Agree x 1
          • pishta
            pishta I know I'm right....
            21,445
            10828
            Oct 13, 2004
            Tustin, CA
            Local Time:
            5:22 AM
            Check out vice grip garage on youtube. The guy sprays his truck in white for like $80 bucks. Came out pretty good for a beater truck. I don't think he's a painter so he won't speak down to you as an authority on the work.
          • barbee6043
            barbee6043 barbee 6043 FABO Gold Member
            15,218
            8260
            Jul 20, 2008
            Shepherd, Texas ( SE Tx)
            Local Time:
            7:22 AM
            ^^Paint is tested not at the day after you shoot it, but 5 -10 years later///.,!
            • Like Like x 1
            • Outsder
              Outsder way back when
              163
              93
              Sep 5, 2019
              Northwest
              Local Time:
              5:22 AM
              So back to the op, charliec, did you get anything useful out of these posts and make a decision about what to do?
            • charliec
              charliec FABO Gold Member FABO Gold Member
              662
              1239
              Jun 13, 2017
              richmond texas
              Local Time:
              7:22 AM
              You bet, I did. I know that I have a lot more hours to put into primer/filler/blocking!!! Then, since I'm not looking for show-quality, I will probably go single stage. Looking for the right color also. The car was yellow with black vinyl top when I bought it, and that really appealed to me. I am trying to identify the correct yellow. I think Plymouth called it "sunfire". It's not a knock-your-socks-off bright yellow. It's a little muted, but not pale.
              I appreciate all the advice. Very helpful.
              • Like Like x 2
              • barbee6043
                15,218
                8260
                Jul 20, 2008
                Local Time:
                7:22 AM
                You can go to TCP Global Color Library for ppg charts that gives you an idea for OEM choices for that yr..
                • Thanks! Thanks! x 1
                • barbee6043
                  15,218
                  8260
                  Jul 20, 2008
                  Local Time:
                  7:22 AM
                  WAYyyyyy back in the 60's I had worked after school (17 yrs old) and had enough $$ to buy a brand new 2 horse side by side trailer. I was so damned proud. The trailer manu. had a new method to "preserve" those wooded 2 x 10 floor boards. They undercoated the heck out of the bottom sides and laid a really think coat of tar (probably in thick!) over the top side, then rubber mats on that. About a year later, I had just loaded a horse and his foot went thru the floor!!!! Dry rotted! in a year!
                  Reminds me of Por 15 somewhat.
                  I have restored more than my share of old Mopars since about '95, I get along well with Good epoxy primer, urethane primer, sometimes a little polyester primer, acrylic urethane, Rusteolum ( NO not the top coat) and staying away from most all aerosols!!!
                  Disclaimer: Your results may vary. :lol:
                  • Like Like x 1
                  • DesertRat
                    DesertRat Well-Known Member
                    3,144
                    2803
                    Jan 22, 2005
                    Moses Lake, Washington
                    Local Time:
                    5:22 AM
                    I'm a fan of epoxy primer, high build sandable, polyurethane single stage. I like PPG concept but our local vendor is dropping it, says it's too expensive. I'm bummed because I have a half gallon of color left from my Barracuda build and the rest and have a comet cyclone to paint that codes out red on white and I am thinking about painting the car the same color as my Barracuda.
                  • 70dart340
                    70dart340 FABO Gold Member FABO Gold Member
                    1,212
                    726
                    Aug 10, 2007
                    Puget Sound
                    Local Time:
                    5:22 AM
                    For what's worth, I like the POR-15 products. No, I don't work for them. Frame parts, like my bumper mounts were sandblasted and brush coated and left to dry. It self leveled, and brush strokes were gone. I can still read the factory part numbers. YMMV.
                    • Agree Agree x 1
                    • charliec
                      662
                      1239
                      Jun 13, 2017
                      richmond texas
                      Local Time:
                      7:22 AM
                      I bought a sample of single stage acrylic urethane at Tasco. Color is Soft Yellow, 81574 SS1. My painting skills suck, but we nailed the color I was shooting for.
                      • Like Like x 2
                      • barbee6043
                        15,218
                        8260
                        Jul 20, 2008
                        Local Time:
                        7:22 AM
                        You can use acrylic urethane as the base IF you want to clear it.
