[SOLD] I have a complete minus carb 1970 Olds 350 engine
trudysduster
Corinth, Ky.
Its not a Mopar but I have dabbled in a lot of stuff. I know if you are a car guy you must know a lot of people and this engine needs to go to a good home. It is out of a 1970 Olds Cutlass. It is a L74 engine. Last year of the high compression engines. It is a 350 with 10.25:1 compression. It is 310HP with 390 lbs torque. casting # is 3955582 and vin code # is 30M375915.It has been in the family since it came out new. Engine was pulled 15 years ago and has been sitting inside covered. It still spins freely. I wouldn't hesitate to change a few parts and fire it up. I have nothing to put it in and it needs to go to a good home. Needing $300 for it. It will make someone with an old car a good engine. pass it around. It is located in Dry Ridge, Ky. zip 41035.
Are you ok with palleting/shipping the Olds 350 engine?
Possibly. You would have to arrange carrier and take care of the cost plus the cost of palletizing it. I believe you could use R.L.Carriers. We could possibly work out something.
