1. FJRdoc
    FJRdoc FABO Gold Member FABO Gold Member
    1,189
    662
    Dec 29, 2009
    Brownstown, PA
    Local Time:
    9:46 AM
    I have been battling a leaky 727 pan for about a year. I tried multiple gaskets and finally purchased the Mopar reusable gasket. Unfortunately, the pan still dripped from the front left corner. I also had a leak from the speedo pinion shaft.
    I decided that this was the weekend that I was going to make the tranny drip free. I took out the speedo carrier and pinion ad made a trip to the local transmission shop. They had a seal that fit and has a spring around the lip to give a better fit.
    I removed the tranny pan and meticulously cleaned all surfaces on the pan and tranny. The lip of the pan was flat and showed no signs of overtorqueing. I have a tube of Hylomar Blue which I have used in the past. I applied a thin coating to all surfaces and let it tack up. Bolted everything back together and torqued to 100 inch pounds. Finally, no more red fluid on the garage floor!
    • Like Like x 9
    • 512Stroker
      512Stroker We are all here because we are not all there.
      3,130
      2477
      May 30, 2016
      Freedom, MO
      Local Time:
      8:46 AM
      The pan will leak just give it time. Sorry
      • Agree Agree x 2
      • FJRdoc
        1,189
        662
        Dec 29, 2009
        Brownstown, PA
        Local Time:
        9:46 AM
        Way to burst my bubble Stroker.
        • Like Like x 1
        • 512Stroker
          3,130
          2477
          May 30, 2016
          Freedom, MO
          Local Time:
          8:46 AM
          I recently had a really bad time with a 727 pan I tried all the tricks and the bastard still seeped.
          I fixed it so it never bothers anyone again.
          • Like Like x 14
          • Thanks! Thanks! x 2
          • Agree Agree x 1
          • FJRdoc
            1,189
            662
            Dec 29, 2009
            Brownstown, PA
            Local Time:
            9:46 AM
            I guess you could say that pan was not bullet proof.
            • Agree Agree x 3
            • 74 360 dart sport
              74 360 dart sport Well-Known Member
              257
              92
              Jan 24, 2019
              Montevideo
              Local Time:
              8:46 AM
              A friend of mine owns a transmission shop showed me a trick back in the 80's with the bottom side of the pan down take a ball peen hammer put the edge of the pan on the end of your bench or vise tap every hole back out it creates a better seal when tightening the bolts back up
              • Like Like x 3
              • Agree Agree x 1
              • Mopar44134
                Mopar44134 Well-Known Member
                399
                281
                Jul 20, 2011
                Ohio
                Local Time:
                9:46 AM
                Thats funny.
                By the way...anyone try the speedmaster tranny pans?
              • j par
                j par Well-hung Member
                28,344
                16242
                Jul 2, 2014
                Portland Oregon
                Local Time:
                6:46 AM
                I also do that with oil pans..
              • ocdart
                ocdart Inland Mopars Car Club FABO Gold Member
                9,148
                3368
                Nov 5, 2006
                North OC, SoCal
                Local Time:
                6:46 AM
                • Like Like x 1
                • Jim Kueneman
                  Jim Kueneman FABO Gold Member FABO Gold Member
                  2,185
                  4398
                  Jul 26, 2016
                  Sonoita, Az
                  Local Time:
                  7:46 AM
                  I have read Hylomar is suppose to be the ultimate but it very expensive. Nice to know it was not just hype. Thanks. I have a 904 that I am struggling with, may have to give that a try.
                • RBConvert
                  RBConvert Well-Known Member
                  246
                  257
                  Apr 20, 2012
                  Lincoln, CA
                  Local Time:
                  8:46 AM
                  A couple years ago I installed a B&M deep sump pan with the Moroso "blue" gasket on the Coronet. No leaks yet. The OEM pan wasn't leaking either, but I wanted the additional capacity and the B&M comes with a sending unit.
                • pishta
                  pishta I know I'm right....
                  21,422
                  10808
                  Oct 13, 2004
                  Tustin, CA
                  Local Time:
                  6:46 AM
                • FJRdoc
                  1,189
                  662
                  Dec 29, 2009
                  Brownstown, PA
                  Local Time:
                  9:46 AM
                  A little Hylomar goes a long way. Spread a small bead and then smear it out with your finger. Let it sit for about 10 min. to let the solvents evaporate and bolt together.
                • missing linc
                  missing linc Loose nut behind the wheel
                  4,554
                  8627
                  Feb 17, 2019
                  Southern Alberta Canada
                  Local Time:
                  7:46 AM
                  Had that problem with a 904 pan in my first Dart, friend of mine owned a trans shop, and I had him do a service on it. He tossed the original pan in the parts washer and put a different one back on. Well it leaked and leaked, and leaked more. I took it back to him 3 or 4 times, but it just kept leaking. Finally he got fed up and put a different pan on, no more leaking. We took the leaky pan and beat it to death with a sledgehammer and then cut it up with an air chisel. I had exceptionally clean transmission fluid after that!
                  • Like Like x 1
                  • ocdart
                    9,148
                    3368
                    Nov 5, 2006
                    North OC, SoCal
                    Local Time:
                    6:46 AM
                    • Like Like x 1
                    • Thanks! Thanks! x 1
                    • j par
                      28,344
                      16242
                      Jul 2, 2014
                      Portland Oregon
                      Local Time:
                      6:46 AM
                      Don't forget the selector seal can look like a pan leak...
                    • moparmat2000
                      moparmat2000 FABO Gold Member FABO Gold Member
                      20,170
                      9496
                      May 13, 2010
                      Grand Tetons
                      Local Time:
                      8:46 AM
                      Not only bullet proof, it wasnt billet proof either. That finned aluminum pan looks sexy..
                      • MoparMike1974
                        MoparMike1974 FABO Gold Member FABO Gold Member
                        3,485
                        2808
                        Jun 16, 2017
                        Maryland
                        Local Time:
                        9:46 AM
                        ...and in most cases is the culprit. Another is the KD pin at the tailshaft gasket surface. I fill that with silicon and no leaks.
                        • Agree Agree x 1
                        • FJRdoc
                          1,189
                          662
                          Dec 29, 2009
                          Brownstown, PA
                          Local Time:
                          9:46 AM
                          I checked every other potential source of transmission leak and found nothing. The selector seal and dipstick tube were all dry.
                        • pishta
                          21,422
                          10808
                          Oct 13, 2004
                          Tustin, CA
                          Local Time:
                          6:46 AM
                          I had one leaking out the kickdown lever pin. (iirc its exposed on passenger rear of case) a blob of RTV finally fixed it. I didnt think the ATF went that high but it was all over the place after a drive and must have just settled and dripped off the lowest point, the pan corner.
                          @MoparMike1974 beat me to it.
                        • MoparMike1974
                          3,485
                          2808
                          Jun 16, 2017
                          Maryland
                          Local Time:
                          9:46 AM
                          Yes, I have seen them leak even with new o-ring in place. I just got to where I rtv it up from the get go.
                        • Ricks70Duster340
                          Ricks70Duster340 Child of the King FABO Gold Member
                          640
                          427
                          Feb 8, 2021
                          Sisterdale, TX
                          Local Time:
                          8:46 AM
                          I use the same TCI pan. Love it. Have had it off several times. I just wipe off the gasket & flange & reinstall. No leaks. Expensive, but worth it to me.
                          • Like Like x 1
                          • MOPAROFFICIAL
                            MOPAROFFICIAL FABO Gold Member FABO Gold Member
                            9,476
                            8831
                            Jun 1, 2016
                            Oceanside ca.
                            Local Time:
                            6:46 AM
                            Same ,leaking 518 pan. Gaskets, moroso re usable, stock pan, derale pan...
                            Still gets wet at the front and leaks drops.
                            Irritating.
                            I used to have great luck using a little 3M adhesive between the gasket and the pan letting it set and then cleaning with some alcohol on a rag the edge of the transmission surface and then just bolt it together with a 1/4 drive.
                            Might just try that again.
                          • RustyRatRod
                            RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                            79,595
                            58104
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            9:46 AM
                            Put a 4 speed in it.
                            • Like Like x 2
                            • Agree Agree x 1
                            • Ricks70Duster340
                              640
                              427
                              Feb 8, 2021
                              Sisterdale, TX
                              Local Time:
                              8:46 AM
                              Now Rob.... !
