j par
Well-hung Member
I called him last month and he said he was going to have me back out for some more stuff so I'll take a lot more pictures and if you have any questions I'll be able to look at his. Also I know he has a manual...
It was bought in Northern Washington..
There's definitely signs of it being a military truck used in Alaska or on its way there... On the passenger side firewall there's a massive brass canister that circulates hot water from the engine that surrounds a coil that runs fuel through it. More or less to warm the fuel... I had him bypass it so it's not to have anything get mixed up by accident but definitely told him to polish it up and leave it there.. in our climate here it's not needed but is nice to have for A conversation piece...
The red wire is just a jumper a cut off and made to hot up the coil.
All you need to do with that starter is to buy a 60-70's Ford fender mount relay. It must be grounded to operate the coil. Either large term to battery + and the remaining one to the starter. the small "S" terminal goes to the start signal at the key or starter push button, and the remaining small terminal "I" is your coil bypass. Just run a wire direct from there to the coil+ and that will give you the ballast bypass "hot voltage" to start
Yup it’s bad ***. More pics. Switching from 6 to 12 volts you’ll have to do all the light bulbs as well as all of the common things. Wiring, starter, battery (duh), points. Some old guys I’ve talked to like the 6 volt stuff but I think it’s nostalgic more than anything else.
Well to be honest, when I did a 51 Chevy 6 to 12 volt conversion I just told you what I replaced. But then I read Del’s, @67Dart273 post and questioned myself. I’m not sure if it is necessary to replace them but I did. If you have some known good points/condenser set from a 12v system id say try em.I some how missed this but the 6V points and condenser WILL NOT work with 12V?
Should I try and retro fit the 1970s 12v parts (condensor & points) into the 1940s 6V housing?
Are there grounds from frame to engine? Might try that.
Cope I dont see a distinct wear mark on the tang of the rotor. How’s the button on the under side of the cap?
No. Old style starters always run the correct direction regardless of polarity. If it was a mini starter polarity matters but it would not crank backwards because of the bendix drive--starter would just spin, ratcheting the bendix.This truck appears to be wired as negative ground and i have the engine fan spinning the correct direction.
If it was a positive ground wouldn't the fan spin backwards?
Is there voltage at the points.
