How I can record a live conversation on my phone. Is there an app for it? Thanks. Kim
Even if you did record a conversation on your phone (as an example for evidence against someone), it would be inadmissible in court unless the person you were recording the conversation with was aware of that fact prior to recording.How I can record a live conversation on my phone. Is there an app for it? Thanks. Kim
All he needs is a warrant. lolEven if you did record a conversation on your phone (as an example for evidence against someone), it would be inadmissible in court unless the person you were recording the conversation with was aware of that fact prior to recording.
They probably have every phone conversation he's had in the last 10 years!!!Just file a Freedom of Information Act with the CIA/NSA and maybe they can give you a recording .
As stupid as it is... only one person has to be aware that you are recording a conversation in Canukistan.Even if you did record a conversation on your phone (as an example for evidence against someone), it would be inadmissible in court unless the person you were recording the conversation with was aware of that fact prior to recording.
Not necessarily. Most all states are one party consent. As long as one party is aware of the recording, it's legal to do.Recording calls is illegal in some places without permission.
An XR?JDM, my phone is a XR. I don’t have the extras. Kim
That would work if I could remember what he said. KimAn XR?
Then it sounds like you just need to use the calendar feature that is already there.
On the little square that has the date on it, tap.
It should open a full month calendar, on the little arrow in upper left corner, tap and it will open a full year calendar.
Find the month and day of your appointment and tap, it should highlight the date. Tap on the + sign in right hand corner and it will open a window that you can add an event into.
There you can set the reminder with your notes etc.
I use this daily, its the best way for me to keep track of appointments for myself as well as work and other projects.
I find its better than using a voice recorder because I don't have to rewind or listen to old notes to get to what I want.
That's why you make the note when you set up the event.That would work if I could remember what he said. Kim
