Rmoore
72 dart.... Super stock springs, Dana 60 3:73....moved the springs in. Fixing to cut the wheel tubs. Need all the tire I can get. 727 with a brake, 5500 jw conv. Will have mufflers. It will be a street car !! 440/512 is what I'm building. 10.5 compression. 270 Trick flow heads max wedge ports with a mopar performance tunnel ram. Two 4150 750 cfm vac secs carbs. Cam motion cams ground the cam that i ask them to. .674 lift 1.6 rockers 296 duration ground on a 112 lobe angle. What's y'alls opinion ?? Would love to be in this group somewhere in the 9s
