I want to replace my vinyl top.
Mopar Body and Trim
  1. Mick Semantel
    Mick Semantel Well-Known Member
    393
    1
    Feb 9, 2005
    Minnesota
    Local Time:
    5:05 AM
    My top is getting beat up, and I would like to replace it. Anybody have tips for me? Do I have to pull the front and rear glass? Any help appreciated.
  2. Bill McLeese
    Bill McLeese Active Member
    33
    0
    Oct 16, 2006
    windsor Ontario Canada
    Local Time:
    5:05 AM
    I pulled all my moldings around the front and rear glass,took the vinyl top off.Then i sanded the top smooth and primed it .Took it to a friend of mine that does tops and upolstery.He had to put a few new clips into hold the chrome on.He made a new top and put it on for me for $400 .So you do not have to remove the glass
  3. 340john
    340john Well-Known Member
    1,667
    33
    Jan 14, 2005
    Edison, NJ
    Local Time:
    11:05 AM
    I have installed a bunch of vinyl tops over the years. On Darts, you don't need to remove the glass, but the moldings do need to come off. I remove the old top, sand off all the old glue residue, then I epoxy prime the roof. I mark the center of the windsheild and the rear window with masking tape and lay the new top on the roof and line up the center of the vinyl with the center with the glass. Tape the vinyl in the center so you can fold it back reveling half the roof. I start in the middle of the roof and apply the adhesive to the vinyl and the roof and lay the vinyl down streching and working out air bubbles and wrinkles. I do one side at a time, after one side is complete I move to the other side. After you are finished glueing and are satisfied with the top, trim off the excess and reinstall the moldings.
    • Thanks! Thanks! x 1
    • Mick Semantel
      393
      1
      Feb 9, 2005
      Minnesota
      Local Time:
      5:05 AM
      Thanks for the help, guys.
    • jos51700
      jos51700 Green Bearing thread connoisseur
      6,371
      3252
      May 24, 2009
      Bel-Ray
      Local Time:
      5:05 AM
      Blast from Da Past! Great little write up!!
