cuda_roller
Mopar rookie
There are no markings on it.
I was just about to link this to you, that is the exact process to do it
Got to be an 8 3/4. I see the thrust spacer between the spider gears.What is the diameter where the ring gears bolts? 8 3/4, 9 1/4, and 8 1/4 all used that cone style carrier.
Yes sir. That's my how to that was linked in post #3. Thanks!I "think" @RustyRatRod did a write up. I can't find it. Might have been another well known member. Craig
Yep. I see it now. And the dowel that holds the center pin.Got to be an 8 3/4. I see the thrust spacer between the spider gears.
