idle too high, makes undriveable
Fuel and Air Systems
  1. phaelax
    phaelax Well-Known Member
    352
    101
    Sep 3, 2014
    Ohio
    Local Time:
    1:49 PM
    Finally got some time to figure out where the gas was leaking with the new carb, it was the new dual feed fuel line. It's a quick fuel 750 with electric choke. The carb's instructions say the fast idle speed should be around 1600rpm, which it is. But as the car warms up, it gets faster and ends up idling at 2k when I expected it to go lower once it warms up.
    Drove it around the block a few times and it's nearly undriveable. With the idle so high, it's harder to control and I'm really having to mash on the brakes to keep from launching at stop signs. But then it's also misfiring if I try to floor it. Too much gas? Not enough? Do I adjust the primaries or secondaries?
  2. khuebner250
    khuebner250 FABO Gold Member FABO Gold Member
    869
    878
    Jun 3, 2005
    Windsor, CO
    Local Time:
    11:49 AM
    Vacuum leak?
    • Agree Agree x 4
    • Like Like x 1
    • toolmanmike
      toolmanmike FABO MODERATOR Staff Member FABO Gold Member
      58,783
      46232
      Jan 18, 2006
      Iowa
      Local Time:
      12:49 PM
      Yep, something is messed up. The fast idle cam should be free and you should be able to tap the gas and kick it off fast idle.
      • Agree Agree x 3
      • harrisonm
        harrisonm Well-Known Member
        3,184
        3286
        Jan 16, 2005
        Topeka, KS
        Local Time:
        6:49 PM
        I guess it could possibly be a vacuum leak, but I think not. Vacuum leaks will usually keep an engine from idling at all. I would say it was definitely carb related. I am not a Holley expert (in fact I don't like them at all), but I would say you have one of 4 things going on:
        1. Choke fast idle circuit not disengaging when warmed up. Find the fast idle cam and ensure it is completely disengaged when warm. It could be a problem with the fast idle screw, or the choke linkage travel may need be adjusted a bit so that the fast idle circuit will disengage when warm.
        2. Choke adjustment. Kina covered in #1. The choke linkage travel must be adjusted so that the choke plate closes when cold (you will, of course have to hit the accelerator linkage one time on a cold engine to set the choke) and opens fully when open. The choke linkage MUST also disengage the fast idle linkage.
        3. Mechanical idle screw and/or idle mixture screws set so poorly that the engine is idling at 2K.
        4. It is possible that the secondaries are partially open. I had that happen on a Holley several years ago and it resulted in a very high idle. Look down the carb throat to see. It's been SO long since that happened, I don't remember what I did. I seem to remember using some carb spray and fiddling with the linkage.
        Now don't take this wrong, but how much do you know about carbs, carb linkage and choke operation? If you don't know anything about how the choke and the fast idle linkage works, you will need some help. If you do understand it, you should be able to fix the problem pretty easily. I can almost guarantee that it is one of the 4 things above.
      • sport74
        sport74 Well-Known Member
        439
        98
        Mar 26, 2014
        Anderson sc
        Local Time:
        12:49 PM
        Most definitely check for vacuum leaks. Just had a similar situation, but I'm running a race carb with no choke. First start up we idled it up to 2500 rpm which didn't take much adjustment. After break in, I tried totadjust the idle to set point. It wouldn't go below 1200 and that's when I heard what I thought was just air going into the carb. I got to searching and found a 3/8 Barb I had overlooked that was open. I put my finger over it and the idle dropped down to 3 - 400 before it died.
        • Agree Agree x 2
        • phaelax
          352
          101
          Sep 3, 2014
          Ohio
          Local Time:
          1:49 PM
          Nothing really. Just what I can read from a book or find online.
          I'll check for vacuum leaks, but I don't think that's it. All the barbs came capped when I bought it, so the only ones missing are what I removed to connect hoses.
        • sport74
          439
          98
          Mar 26, 2014
          Anderson sc
          Local Time:
          12:49 PM
          Could be a leak elsewhere, use carb cleaner to gently spray around the intake everywhere that could leak, vacuum ports, intake runner plugs, carb mating area, even intake gaskets. Anywhere air could get in is a possibility of a vacuum leak. The idle will change as you spray an area with a leak. I have done this several times with starting fluid, but that is very dangerous, one stray spark and whoosh it's on fire! Carb cleaner is no where near as volatile and therefore safer
        • toolmanmike
          58,783
          46232
          Jan 18, 2006
          Iowa
          Local Time:
          12:49 PM
          You never mentioned that you tapped the gas to kick it off the fast idle. You should be able to do that at any time after the engine fires. I usually let mine warm up a few min. first. And yes the idle will increase as the engine warms up. You should take off the air cleaner and start the engine cold and watch everything that the choke and fast idle cam does. Once you understand how it works you will be able to fix it.
        • Bulldozer
          Bulldozer free ice cream sandwiches
          15,527
          2358
          Oct 16, 2011
          behind the wheel
          Local Time:
          12:49 PM
          also make sure your throttle cable isn't adjusted so that it's not letting the butterflies close completely rendering the idle screw useless
          • Agree Agree x 3
          • Like Like x 1
          • dano
            dano Evil Handy Man
            3,755
            1604
            Aug 22, 2005
            Gresham, Oregon
            Local Time:
            10:49 AM
            Disconnect all vacuum lines and plug to isolate. What is the timing set to? Some Holley based carbs have a manually adjustable secondary to allow more air at idle without opening the primary too far and exposing the transfer slot. What model is the carb? Have you looked down the carb with it running to see if fuel is leaking or running down? Floats could be too high and or too much furl pressure. Electric choke is wire up and working? History of carb?
            • Agree Agree x 1
            • robert flippo
              robert flippo Well-Known Member
              258
              184
              May 9, 2018
              gibson station va
              Local Time:
              1:49 PM
              I have a 600 Holley on a 318 with high rise, i was having same problem, at the back of carb was a vacuum line, i guees it was for power steering which i don't have, i capped that hose connection off and went from about 1800 rpm at idle down to about 800.But sounds like either a vacuum leak or hose not connected, possible fast idle linkage needs adjusted
            • famous bob
              famous bob mopar misfit
              19,591
              8649
              Aug 14, 2011
              okla
              Local Time:
              12:49 PM
              SOUNDS LIKE TIMING OR A VACUUM KEAK. DID IT EVER BACKFIRE ? COULD HAVE BLOWN A CAP OFF A VACUUM LINE .
              • Agree Agree x 2
              • phaelax
                352
                101
                Sep 3, 2014
                Ohio
                Local Time:
                1:49 PM
                Brand new carb from Jegs:
                Quick Fuel SL-750-VS: 750 CFM 4 BBL Elect. Chok | JEGS
                I haven't had a chance to try anything since last time I posted so nothing new to update yet. And with just an unenclosed carport, I doubt I'll be working on it in this weather any time soon.
