grr8_65
Everyone says to mill the heads in order to increase the compression, would there be any benefit to milling the block, if you could get it in the milling machine? :-k
As I understand it, Milling the block can be done. You would mill the block to zero deck the pistons. Doing the heads would decrease the chamber size. I was planning on getting my block milled to help bring the pistons closer to zero, but as it turned out, the KB 167 pistons coupled with the "302" heads I had brought me up to the 9.5:1 I was looking for so no milling was needed. Either way, if you take off too much material from either, you will change the geometry of the valve train and have to compensate with shorter push rods at the very least.
To follow up then, Which is better a small combustion chamber, or a large chamber with a modest to no deck height ?
ok, I was curious on that question as well, but moparkid please explain. What does "slant not SB" mean? How does milling the block keep the valves away from the piston? If you take material off either surface, the top of the piston and the valve are going to be closer together. What am I missing?
"Slant" motors are inline 6 cylinder motors that are inclined at a 30 degree angle from vertical. "SB" is referring to small block "V" motors with 2 heads. If you take from the block, and not the head, the valves stay tucked in the combustion chamber rather than protruding out from the head's deck into the cylinder bore when at lift. That way in case of a timing failure (Broken timing chain, etc.) your motor is safe from bending valves from valve to piston contact. This is called a non interference motor. If you milled the head down to the point that the valves protrude from the deck of the head into the cylinder bore and the timing chain breaks... some valves will be stuck at lift, and as the piston rises it will smack the valve. No good! That's aptly called an interference motor.
Cheers!
Drake
Also, keep in mind that once you mill off so much off of the heads and/or block, you may have to mill the intake manifold for it to fit right.
ideally you would put in 9.5:1 kb pistons, and the block and heads would be milled appropriately so that you get the right quench, and that everything is square & true
(blueprint specs)
Straight six, this wont mater. If using headers and you have power steering there may be a clearance issue with one of the runners contacting the adjustment screw on top of steering box. A shim under the left motor mount or a ballpeen hammer corrects that issue.
Stock pistons stay well below block deck height on a slant, making it a noninterference engine. Removing up to 0.100 from factory dimensions form head or block is about the limit before having to use custom length push rods.
My understanding is that removing material from the block is preferable to shaving head on these engines due to how far down stock pistons reside in their bore at top dead center.
Before you pull a cut depth out of thin air, you need to pull the head, measure what you have, and utilize a compression ratio calculator to design a configuration that keeps dynamic compression ratio in line with pump gas use.
all KB has that ive found are the flat tops and then the dished piston for the later LOW comp slants...
"Slant" motors are inline 6 cylinder motors (single head) that are inclined at a 30 degree angle from vertical. "SB" is referring to small block "V" motors with 2 heads. If you take from the block, and not the head, the valves stay tucked in the combustion chamber rather than protruding out from the head's deck into the cylinder bore when at lift. This is exaggerated even more by high lift radical cams. That way in case of a timing failure (Broken timing chain, etc.) your motor is safe from bending valves from valve to piston contact. This is called a non interference motor. If you milled the head down to the point that the valves protrude from the deck of the head into the cylinder bore and the timing chain breaks... some valves will be stuck at lift, and as the piston rises it will smack the valve. No good! That's aptly called an interference motor.
Cheers!
Drake
Ok, I knew what the difference between a slant and SB is, I just didn't follow what he was referring to in reference to my post....still don't.
This thread is about apples (slant 6) and your talking about oranges (small block).
Why are you talking about oranges,when the thread is about apples ?
To the OP. Yes,you can shave the block,or head,or both.
You will have to do the math to keep the compression where you want it.
I like oranges better I guess. :tongue10:
As I was scrolling down to the bottom of this thread I noticed something and had to scroll back up....yup....slant forum. Hadn't noticed that before. I had just clicked on the new link that came up on my main page. Scrolled down hoping no one had posted yet....bummerops:
I'm gonna shut up now
