Indy 360 Intake images
joes68340s
Rescue CA.
Im looking for people running Indy 360 intake and what they use for throttle cable bracket and return spring bracket. looking for images. Thanks
I use the Jegs bracket that bolts to front and rear carb bolts on the drivers side. It has the provision for the factory cable and has its own double return springs. I used it with the 360-1 intake and my present Victor W2
I used the Jegs bracket too on my W2 combo, Edelbrock head combo, and Indy head combo. This is my current Edelbrock combo but the same bracket
I went through my box of throttle brackets and used two different truck brackets and welded them together to raise the cable holder. I used a 318 2bbl cable. Strong , Not bolted on with carburetor and all factory parts with strong factory cable.
Thanks for the pics. My problem is I have bosses on the upper side of the bolts. Probably for Magnum heads. So im stuck with carb mount bracket.
It kind of blends in with the carb. But here is the throttle bracket I am useing. Its a nock off I bought off ebay for $40 I think. Also I am useing it with rhe stock throttle cable.
