indy 440-2 intake
earthmover
in the tire smoke
nc
whats this intake worth it has about 50 runs on it and is coated gray nice intake but may need a 400-2 instead.....:cussing:
Are you having issues with it seating to the heads? When you put the manifold down do you have gaps between the flange and the head? are you trying to put the manifold on low port set of heads? If yes to all of the above you will need to mill some areas on the back of the manifold.
no prblem i may just end up going low deck 400 to make 512 havent made my mind up yet but all the reading and post say the 400 webs are stronger ..im lookingh for around 750hp with the motor with some -1 heads and a roller set up...so i may have to get the 400-2 to fit the low deck block thats all..mike :headbang:
