SS Lancer
Hello bought above unit which excepts smallblock Chevy water pumps . Please explain the benefits of running this and will motorplate still be able to be use ,
cools the head first, then in to the block and then on to the radiator. cool heads make more h.p.The water can flow through the motorplate just like normal. You will need longer bolts. I have no clue of the advantage but my B1 head motor has lines tapped into both sides of the pump to feed the heads besides the block. My setup has AN-16 lines from the plate to the radiator. Kinda a specialized deal IMO only needed for special setups.
