moparfreak52
Active Member
i'm wondering if someone has a wiring diagram for a 66 barracuda fs TACHOMETER i'm trying to find out if there's 2 wires coming off the TACH. any pictures and information will be helpful THANKS
Red wire power
Black wire ground
Green wire, signal from ignition coil
White wire, back light to work with dash lights circuit.
Is usually how most tachs are wired.
Tach has to be grounded in order to function. Grounding on 66's tachs are through the cluster via the instrument panel ground to body. On 65's, the tach has two wires attached to the back of the tach. One yellow wire from the sending unit and a black or brown dedicated ground wire.
