1. moparmike67
    moparmike67 New Member
    3
    0
    Oct 18, 2009
    Local Time:
    11:58 AM
    Anyone know if a B body inland shifter will fit on an A body non console car? My 68 Formula S clone needs correct type shifter to look right.Just bought an Inland shifter at a swap meet,and vendor thinks that it is from a B body. To me it looks like all the ones I have seen in 68 Barracudas at car shows and the 68 sales brochure. Just want to unbolt the 3 bolts and use the chrome lever.I do not know if the angles on the shifter will interfere with anything. Any info would be greatly appreciated.
  2. TheDeputy
    TheDeputy Well-Known Member
    231
    0
    Aug 20, 2008
    Local Time:
    7:58 PM
    Here are some pics of how the shifter is supposed to look in a bench shifted car.
    Antoon
  3. moparmike67
    3
    0
    Oct 18, 2009
    Local Time:
    11:58 AM
    Appreciate the pics Deputy. I forgot to mention that my car has Bucket seats.](*,) That would make a difference.
  4. matthon
    matthon Well-Known Member
    1,887
    246
    Aug 29, 2008
    Local Time:
    12:58 PM
    Is that your shifter, or just a pic you had?
  5. Outsider
    Outsider Well-Known Member
    530
    2
    Feb 15, 2009
    Local Time:
    11:58 AM
    The only experience I have with a B-body Inland was in a '67 Hemi GTX. That was a non console Inland, and it was longer than an A-body Inland.
  6. moparmike67
    3
    0
    Oct 18, 2009
    Local Time:
    11:58 AM
    Do you think the longer shifter would work? Do you know how much longer it is than the A body one?
  7. Outsider
    530
    2
    Feb 15, 2009
    Local Time:
    11:58 AM
    If I were to hazard a guess, I'd say no it won't work. I do know that all the linkage won't work, and the shifter handle was longer, as well as bent at an angle back to the driver, that the A-body shifter doesn't have. Trade it to a B-body guy for what you need.
  8. TheDeputy
    231
    0
    Aug 20, 2008
    Local Time:
    7:58 PM
    It's a pic I found when I was looking for a shifter. I think this shifter is currently still for sale on ebay for 150 dollar.
    My shifter is a few posts back called home made inland hurst shifter.
    Oh, and the B-body shifter is way too long for an A-body. You will hit the dash when you shift.
    Antoon
  9. 1968FormulaS340
    1968FormulaS340 Well-Known Member
    11,559
    459
    Aug 24, 2005
    St. Helens Oregon
    Local Time:
    9:58 AM
    This is my 68 Formula S with the factory Inland.
    Please note…….. The Inland is only correct for early 68s. A few months into the 68 production run they were changed to Hurst.
    [​IMG]
    [​IMG]
  10. matthon
    1,887
    246
    Aug 29, 2008
    Local Time:
    12:58 PM
    So are there any similarities between the A body Inland and the B body Inland?
    Is the A body bucket seat no console shifter the same as the bench shifter?
    I know the console one would be offset, and my assumption is the bench shifter would not be offset.
    I have a 67 Barracuda with a bench seat that originally had an Inland, and I cannot locate a part number, and no one seems to know if the bench and bucket no console were the same.
  11. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,432
    1289
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:58 AM
    .........Imay have an A body inland...........i thought it was out of a 66-7 coronet, but my buddy says it is out of a 67 bb cuda he used to have.........i would need pics to compare them side by side...........kim.........
  12. 1968FormulaS340
    11,559
    459
    Aug 24, 2005
    St. Helens Oregon
    Local Time:
    9:58 AM
    Just looking at mine…… I wouldn't think it would work very well with a bench seat.
    But I could be wrong.
  13. matthon
    1,887
    246
    Aug 29, 2008
    Local Time:
    12:58 PM
    Does yours look like the shifters pictured in this thread?
    Its all I have to go on at this point.
    I would be interested in yours if it is correct.
  14. matthon
    1,887
    246
    Aug 29, 2008
    Local Time:
    12:58 PM
    Here's a few pics of a Hurst with a bench, for what its worth.
    It is not offset to one side or the other at all:
  15. 1968FormulaS340
    11,559
    459
    Aug 24, 2005
    St. Helens Oregon
    Local Time:
    9:58 AM
    Mine is the one in post #9.
  16. matthon
    1,887
    246
    Aug 29, 2008
    Local Time:
    12:58 PM
    I was referring to oldkimmer's shifter.
    I believe we were posting replies at the same time.
    Must...get...sleep...now...
  17. oldkimmer
    10,432
    1289
    Nov 11, 2006
    Local Time:
    11:58 AM
    .............I'll have to check.............how tall is an A body handle.........how long would the shift rods be.........i have the rods and levers....................kim.........
  18. matthon
    1,887
    246
    Aug 29, 2008
    Local Time:
    12:58 PM
    Can anyone confirm how tall an A body Inland handle is?
    oldkimmer - is there a part number on the shifter and/or the handle?
    1968FormulaS340 -
    In the pic of your shifter, is it in gear, (what gear?), or neutral?
    Where is the driver seat in relation to the shifter, behind it, next to it, or in between?
    If you pull your seat all the way up, does it contact the boot?
    I can't find a pic of a bench shifter installed, so any help is greatly appreciated.
    FYI: I am not trying to highjack this thread, and I am not sure if that is possible based on the age of it and it is not in the parts wanted section, so no disrespect intended. I actually searched FABO for Inland posts, and rediscovered this thread when I searched thru Google.
  19. oldkimmer
    10,432
    1289
    Nov 11, 2006
    Local Time:
    11:58 AM
    .........my shifter is 4 a consol car i presume as it is offset 4 inches........handle is approx 16 in from bottom of base to top of the black nob.........kim.........
  20. Commando66
    Commando66 She's a beaut Clark!
    1,775
    209
    Dec 2, 2007
    Gig Harbor, WA
    Local Time:
    9:58 AM
    Do you know what the number is on the Inland handle? I have one that is 44532 out of a 66 Barracuda with no console.
  21. 1968FormulaS340
    11,559
    459
    Aug 24, 2005
    St. Helens Oregon
    Local Time:
    9:58 AM
    Where is the # located. I will go have a look.
  22. Commando66
    1,775
    209
    Dec 2, 2007
    Gig Harbor, WA
    Local Time:
    9:58 AM
    The number is located at the base of the handle where it bolts to the mechanism. Check out the crappy pic below.
  23. A383Wing
    A383Wing Supreme Commander
    129
    0
    Jan 16, 2006
    in my house
    Local Time:
    9:58 AM
    "A" body shifter in first pic..."B" body shifter in second pic
