Anyone have photos of where they had to drill the spot welds to get the inner fender out of their A-Body? I am about to start pulling the left inner fender out of a Duster then one out of a Dart to install in the Dart. This is my first adventure at this level of metal work and I don't want to destroy either one learning
There a lot! I don't have pics but I have done them. Maybe whip into the for sales and look up inner fenders. I know some of the members here have very good pics of what they are selling. You can see the drilled spotwelds on some.
I have blair cutters and have a few along the back top edge drilled and separated. I am just having a hard time recognizing where they are.
If you don't have engine out of car it will be difficult to get to all of them. They are on the bottom attached to the frame rail. More on shock tower and in lower UCA area. Also a series along the piece that attaches to the fire wall. And last but not least to the core support. If you are replacing with a new one, grind out the spot welds on the old piece. Drill spot welds out on donor piece. Remember grinding sparks and welding splash will pit glass. Have fun.
A small pilot hole to control bit walk, a 5 buck HF bit, and a few drips from a can of this stuff………….. An extension for the bit can come in handy as well.
I couldn’t see them all, once you get one out, you can slide a spot weld breaker, or 5-in-1 or screwdriver, or chisel up to id the next one
mine was pretty clean and I hit it with silver paint (all I had) but it made them highly visible. The HF bit works great BUT you need to use a small 1/8 drill to set the pilot hole or itll skate all over the place. I didnt even have to rotate the bit and I took out about 80 welds on a 65. When you weld them back in be very sure your unibody is level and squared up. Use 4 of the same jackstands on the same hard points under the chassis. Even use a tape measure to make sure its all plumb before you tack them in.
