Installing 4 spd pedals
Scubakuda19
Buffalo, NY
Hello, I apologize if I missed it but I searched before I posted. I was wondering if anyone new of a good resource on "how to" install 4 spd pedals properly into a 72 Duster?
Car was a column shift auto, I have removed the dash assembly to redo it and I want to install these pedals. I am going to also replace the steering column with manual steering column for a floor shift car and remove the power steering and replace e with manual box
Thank you.
Unbolt automatic pedals, install standard shift pedals in reverse order. That's it. No extra holes need to be drilled. You will have to add a clutch Zee bar mount bracket to the frame, but the hole is there too.
Thank you kindly, seems like I may be making it more complicated than it is. I do have a Zee bar bracket as well. Thanks again for the info, have a nice evening.
