Installing new filler neck grommet...
Fuel and Air Systems
  1. LivewireBlanco
    LivewireBlanco Well-Known Member
    211
    21
    Jan 14, 2018
    West Texas
    Local Time:
    3:45 PM
    Any tips or tricks to make this install smooth and easier? 1971 Dart.
  2. 1963dartgt
    1963dartgt Well-Known Member
    502
    142
    Nov 7, 2015
    CA
    Local Time:
    3:45 PM
    Vaseline is all i used went in easy no problems.
    • Agree Agree x 5
    • Like Like x 1
    • 1969VADart
      1969VADart FABO Gold Member FABO Gold Member
      2,080
      406
      Aug 19, 2013
      Fredericksburg, VA
      Local Time:
      4:45 PM
      Boil the rubber grommet on the stove for about 10 minutes. That will soften the rubber up a lot. Then it will pop right into the gas tank. Apply some dielectric grease to the grommet once it is in the tank and the filler neck should slide right in very easy.
      • Like Like x 2
      • Agree Agree x 1
      • Daves69
        Daves69 Well-Known Member
        3,953
        1969
        Feb 20, 2011
        WestOfChi
        Local Time:
        3:45 PM
        I didn't need to boil mine. I used the DMT seal and just lubed it a bit. I did remove the three screws from the tube flange/body/cap so it could move a bit. A little painters tape held the pad till I got it over the tube and positioned. Suggest putting the driver side strap into the slot prior to putting the tank up. Passenger side was easy afterward on my B'cuda.
      • Murray
        Murray FABO Gold Member FABO Gold Member
        814
        401
        Apr 19, 2010
        San Jose, California
        Local Time:
        1:45 PM
        Each has their own trick for lubing- I use armor-all- dries clean and is good for the rubber.
      • Dicer
        Dicer FABO Gold Member FABO Gold Member
        450
        433
        Jan 12, 2016
        Land of Lincoln
        Local Time:
        3:45 PM
        Didn't take the time to research, got the wrong seal, went in easy... too easy. Filled the tank and had gas dripping down under the car. Correct seal next go-around what a ...SOB... it was to get it right, used Vaseline for the install and finally fixed it.....
      • 72Duster440
        72Duster440 Well-Known Member
        314
        55
        Aug 2, 2010
        Sterling Heights, MI
        Local Time:
        4:45 PM
        That's how I did mine, put the new grommet on the tank, put the tank in place and then slid the filler right into it. Was easy both times (First time I forgot slide grommet to seal the trunk floor over the tube!)
      • 7milesout
        7milesout Well-Known Member
        296
        53
        Feb 17, 2017
        PTC
        Local Time:
        4:45 PM
        I could not find the right size to fit the aftermarket tank and OEM filler neck on my 72 Scamp. It still pukes a bit at each fillup. Any suggestions on how to modify the seal, in order to … seal?
        7milesout
      • Daves69
        3,953
        1969
        Feb 20, 2011
        WestOfChi
        Local Time:
        3:45 PM
      • 7milesout
        296
        53
        Feb 17, 2017
        PTC
        Local Time:
        4:45 PM
        Daves69 - For $14, I'll give it a try. But I think my problem is … the replacement tank. The size of the opening versus the size of the filler neck and grommet don't jibe. Thanks!
      • Daves69
        3,953
        1969
        Feb 20, 2011
        WestOfChi
        Local Time:
        3:45 PM
        I cleaned and reused the old tank. A seal I purchased from another supplier (without investigating first), the tube would not go at all. I suspect it's for an earlier model.
        The DMT measured very close to the old cracked original. The old one I could make out the PN.
      • 7milesout
        296
        53
        Feb 17, 2017
        PTC
        Local Time:
        4:45 PM
        The one I installed looks like the below. It is from Filler Neck Supply Company, model GR004-02. But like I said, I don't think it's the filler neck, I think it is the size of the opening on the gas tank. I forget the measurements, but this grommet was supposed to cover that size.
