1969VADart
I finally decided to replace my leaky water pump on my Dart. I went ahead and ordered new hoses, themostat, and fan clutch to replace at the same time. I assume that installing the water pump with the supplied gasket should not be an issue. However, I do have one question. Should I use any kind of gasket maker or sealer on the bolt threads/holes for the water pump bolts (also the power steering pump and alternator bolts)? Any advice would be appreciated. Thanks.
