Instrument cluster voltage regulator, on a 1970 Plymouth Valiant, 340 Duster
Electrical and Ignition
  1. DaveM
    DaveM Active Member
    36
    1
    Sep 20, 2018
    Ny
    Local Time:
    4:16 PM
    Hello where is it located on a 1970 Plymouth Valiant, 340 Duster ?
    It is not on the back side of my instrument panel.
    Is it inside the panel or on the firewall, under the dash?
    My temp & fuel gauge read zero...
    I would like to check the IVR if I could locate it!
    Any help or pics would help and be appreciated.
    Thanks in advance
  2. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    24,948
    4258
    Aug 28, 2009
    Ontario
    Local Time:
    3:16 PM
    I believe its inside the fuel gauge.
  3. DaveM
    DaveM Active Member
    36
    1
    Sep 20, 2018
    Ny
    Local Time:
    4:16 PM
    Thanks so I have to remove the whole printed circuit board from the instrument panel to get to the regulator inside?
  4. Dubob
    Dubob Well-Known Member
    1,153
    339
    Oct 28, 2011
    Ohio
    Local Time:
    4:16 PM
    If it’s a rally dash it is part of the fuel gauge. It is not serviceable. I converted my Demon to a solid state regulator.
  5. DaveM
    DaveM Active Member
    36
    1
    Sep 20, 2018
    Ny
    Local Time:
    4:16 PM
    how did you convert, instructions available?able to use your orig fuel gauge/s ? thanks in advance.
  6. Dubob
    1,153
    339
    Oct 28, 2011
    Ohio
    Local Time:
    4:16 PM
  7. 4spdragtop
    24,948
    4258
    Aug 28, 2009
    Ontario
    Local Time:
    3:16 PM
    Dubob has it nailed. The gauge itself has to come out of dash/bezel to work on it. Quite a few steps involved to get to that point.
    Good luck.
  8. DaveM
    DaveM Active Member
    36
    1
    Sep 20, 2018
    Ny
    Local Time:
    4:16 PM
    thank you. but do you think my limiter is bad if my oil pressure gauge works? Both temp & fuel gauge do not work...
  9. DaveM
    DaveM Active Member
    36
    1
    Sep 20, 2018
    Ny
    Local Time:
    4:16 PM
    thank you but since the limiter supplies voltage to the three gauges and only the fuel and temp do not work, do you think its defective/my prob?
  10. Dubob
    1,153
    339
    Oct 28, 2011
    Ohio
    Local Time:
    4:16 PM
    It’s not too hateful. Take your time. But what I don’t understand is if it’s bad the oil pressure won’t work either. You could check to see if you’re getting approximately five volts at the sending units for temp etc. it could be pins loose on printed circuit board or even bad traces etc on the board. Also could need better grounding of the instrument cluster housing.
    Sorry We were typing at same time. If one gauge is working the limitor is operating. Maybe the temp sender is bad, can check with and ohm meter. The fuel could be the sender or the grounding to the tank isn’t good.
    • Agree Agree x 1
    • 4spdragtop
      24,948
      4258
      Aug 28, 2009
      Ontario
      Local Time:
      3:16 PM
      To fix it, the gauges/cluster has to come out. Before that, check oil sender and connections to diagnose.
      Once gauges are out, you can do a newfie check on them with a 6v lantern battery.
      Fuel gauge gotta be fixed anyway right?
    • DaveM
      DaveM Active Member
      36
      1
      Sep 20, 2018
      Ny
      Local Time:
      4:16 PM
      If you are sure the oil press gauge is fed off of it then I will troubleshoot the items you mention. thanks again for your time and support. I will update when I find the smoking gun. thanks again
    • 4spdragtop
      24,948
      4258
      Aug 28, 2009
      Ontario
      Local Time:
      3:16 PM
      Get a factory manual.
    • Dubob
      1,153
      339
      Oct 28, 2011
      Ohio
      Local Time:
      4:16 PM
      Without a doubt the temp and fuel, oil all get their power from the limiter. 12 volts come into the fuel gauge thru the limiter and changes to 5 volts approximately, then thru the windings for fuel gauge out to sender, then thru temp and oil out to its sending unit. Keep in mind the voltage will be a pulsing voltage as the regulator contacts open and close. All the sending units provide a variable resistance to ground. If you check the general section here there should be downloadable manuals if you don’t have one.
      Something else is you could go right to the sending units and see if you have that voltage at the wire. Would help isolate it.
      • Thanks! Thanks! x 1
      • toolmanmike
        toolmanmike FABO Staff Staff Member FABO Gold Member
        35,217
        17194
        Jan 18, 2006
        Iowa
        Local Time:
        3:16 PM
        Thread moved to electrical forum.
      • jimjimjimmy
        jimjimjimmy lobsterman FABO Gold Member
        4,066
        853
        Nov 2, 2010
        p. e. i.
        Local Time:
        5:16 PM
        only the temp and fuel are powered thru the limiter the oil pressure is not .
        • 4spdragtop
          24,948
          4258
          Aug 28, 2009
          Ontario
          Local Time:
          3:16 PM
          I was thinking that but wasnt sure JJJ.
          Thanks.
          • Like Like x 1
          • RedFish
            RedFish Well-Known Member
            22,680
            1680
            Sep 5, 2007
            Local Time:
            4:16 PM
            Rally or not, All thermal gauges operate on a 5 volts. A single limiter/regulator supplies 5 volts to 2 or 3 thermal gauges. Warning lamps operate on 12 volts. If one OEM thermal gauge works, the limiter/regulator is working. Fault at other gauge(s) has to be some other problem, gauge, sender, connections.
          • 67Dart273
            67Dart273 Well-Known Member
            38,641
            6247
            Oct 14, 2010
            Idaho
            Local Time:
            1:16 PM
            No, only the amp gauge is not associated with the limiter. The other three are. The fuel gauge has a 3rd post which is the 5V output and feeds to the oil/ temp gauges. See Red's post above^^
            In fact you can see it in the photo posted, marked 5V
          • 67Dart273
            38,641
            6247
            Oct 14, 2010
            Idaho
            Local Time:
            1:16 PM
            If you thrash around the www there is a procedure to feed an external 5V regulator or IVR into the fuel gauge 5V stud and do away with the internal / OEM one
          • jimjimjimmy
            4,066
            853
            Nov 2, 2010
            p. e. i.
            Local Time:
            5:16 PM
            my apologies to everyone you are right the last thing I want to do is spread bad info .
            • Like Like x 1
            • 4spdragtop
              24,948
              4258
              Aug 28, 2009
              Ontario
              Local Time:
              3:16 PM
              Thanks for clarifying guys.
