intake alignment?
Small Block Mopar Engine
  1. j.d.duggan
    j.d.duggan Well-Known Member
    130
    25
    Dec 4, 2018
    tulsa okla.
    Local Time:
    11:26 PM
    I have a weind stealth intake that cam off a motor that had been squared and decked,pistons came out of holes .020 and the heads had been worked,ported, polished,and milled(not sure how much)I,m trying to figure out if maybe they cut the intake down to match that work.when I put it on my engine it seems to narrow.the gasket seal line on the intake gasket sets high enough on the head that it shows above the intake.any ideas of how to check this? Thanks for help.
  2. H22A4
    H22A4 Well-Known Member
    1,484
    363
    Aug 4, 2006
    YVR
    Local Time:
    9:26 PM
    When’s our set the intake on the engine with the gaskets in place, do the bolt holes line up? In other words can you put in the intake bolts in? Sounds like the threads in the head are too high?
  3. famous bob
    famous bob mopar misfit
    11,233
    2783
    Aug 14, 2011
    okla
    Local Time:
    11:26 PM
    Maybe not any help here, but I stumbled across something that seems to be working well for me , on a 2954 victor. The bolt holes are more perfect than any intake I`ve messed with so far.
    To check port and gasket alignment and to keep checking the same over and over while working on them, I have always used oversize bolts to line everything up , I got the idea of sleeving the 3/8" bolts I`ll be using to run it on the engine, a 3/8" copper sweat coupling with the stop rib filed out of the center fits over the bolt and locates the victor intake perfectly, also works well on the gasket when checking for alinment on the heads too---- just a thot----
    • Like Like x 1
    • Bobzilla
      Bobzilla Well-Known Member
      432
      281
      Aug 10, 2017
      Livonia, Michigan
      Local Time:
      12:26 AM
      Look at the pictures in post 149 of the thread below. He shows what H22A4 is talking about.
      With heads in place, both intake gaskets in place, and intake sitting down in place as much as possible, visually look into the intake bolt holes. They should line up with the head bolt holes.
      Junkyard 5.9L Magnum + Edelbrock LA heads build
      • Like Like x 1
      • j.d.duggan
        130
        25
        Dec 4, 2018
        tulsa okla.
        Local Time:
        11:26 PM
        bolt holes in head are to high,if I lift the intake up I can put the bolts in but then I have pretty big gap between intake and head.thought about bolting one side only down-no gasket,then I could mic the gap between the other head and intake.
      • toolmanmike
        toolmanmike FABO Staff Staff Member FABO Gold Member
        35,218
        17199
        Jan 18, 2006
        Iowa
        Local Time:
        11:26 PM
        Sounds like the intake has been machined. You may need to use 2 intake gaskets on each side.
        • Agree Agree x 2
        • Bobzilla
          432
          281
          Aug 10, 2017
          Livonia, Michigan
          Local Time:
          12:26 AM
          Are you trying to use original style steel gaskets, or the replacement style soft material gaskets?
          Like toolmanmike said, you need more thickness in your gaskets.
        • j.d.duggan
          130
          25
          Dec 4, 2018
          tulsa okla.
          Local Time:
          11:26 PM
          is that not a problem?,do you use some type of rtv between them and on heads and intake?have you ever ran 2 intake gaskets?
        • j.d.duggan
          130
          25
          Dec 4, 2018
          tulsa okla.
          Local Time:
          11:26 PM
          I have a set of paper(for lack of a better word)that came in a master rebuild gasket set.it also has the steel intake gasket.
        • rumblefish360
          rumblefish360 so close yet so far away
          33,469
          5512
          Jun 21, 2005
          New York, on a Island
          Local Time:
          12:26 AM
          How much of a gap do you have?
          I would try 2 intake gaskets glued togther at max but honestly a new intake is the better route.
        • j.d.duggan
          130
          25
          Dec 4, 2018
          tulsa okla.
          Local Time:
          11:26 PM
          do not know for sure rumble,see post #5 will try to get a good measurement tomorrow.
        • MOPAROFFICIAL
          MOPAROFFICIAL Well-Known Member
          2,928
          1928
          Jun 1, 2016
          breakwater
          Local Time:
          9:26 PM
          Felpro has steel, kit style blue composite ms90109 .030ish thick, and race style paper 1213 type with blue pinstriped port/water seals thick .060
          Which are you using?
        • j.d.duggan
          130
          25
          Dec 4, 2018
          tulsa okla.
          Local Time:
          11:26 PM
          blue paper style
        • MOPAROFFICIAL
          2,928
          1928
          Jun 1, 2016
          breakwater
          Local Time:
          9:26 PM
          So the bottom pictured, paper, blue pinstripe .060 thick.
          Buy a new intake, but before that...see how a stock one fits and let us know.
        • j.d.duggan
          130
          25
          Dec 4, 2018
          tulsa okla.
          Local Time:
          11:26 PM
          top pic looks like the one I have
        • MOPAROFFICIAL
          2,928
          1928
          Jun 1, 2016
          breakwater
          Local Time:
          9:26 PM
          Buy the the 1213 then , bottom pic then...its .060/thicker.
          I like the ones you have, they don't sponge oil and rip n delaminate when swapping intakes...and they usually allow a tight manifold to just fit @.030 thick. If I'm milling, I figure for those 90109's.
        • 1969reddart
          1969reddart Well-Known Member
          214
          147
          Sep 29, 2007
          Concord, Ca.
          Local Time:
          9:26 PM
          This is the paperwork that came with my brand new Action Plus. Mine didn't sit correctly either. Too much of a gap between the head and the manifold. I talked to my neighborhood speed shop and he said to "just bolt it up, it should be fine". I used the thick gaskets and still had trouble getting it to seal. Never could get the water jacket to not seep. I bought a RPM Air Gap and it went together perfectly. Anyone wanna buy a gently used Action Plus?
        • mullinax95
          mullinax95 Well-Known Member
          12,888
          328
          Oct 25, 2006
          Anderson, SC
          Local Time:
          12:26 AM
          • Like Like x 2
          • MOPEkidD-3
            MOPEkidD-3 Torsional Member
            3,513
            443
            Jan 4, 2008
            Fort Collins, CO
            Local Time:
            10:26 PM
            Mother ******! lol... I couldn't find those thinner gaskets on Summit I bet they would have solved my problem. If we were closer we could have just traded! I have the bottom ones and am now getting my intake milled because it sits too high... oh well I think the thicker gaskets work better anyway.
          • j.d.duggan
            130
            25
            Dec 4, 2018
            tulsa okla.
            Local Time:
            11:26 PM
            yesterday I put the intake on with no gaskets,.060 feeler gauge under the 4 corners,snugged the bolts down,feeler gauge seemed to lock into place.Think I may be OK with the thicker gaskets.ordered a set,be here in a week,time will tell.:drama:
