pntastar69
What is applied to ARP intake bolts going into aluminum heads holes exposed to oil, sealant or anti-seize?
I don't know why I was thinking intake bolts, but that's what was on my mind. I agree though. I use sealant on every head bolt I install. Blind hole or open. It helps keep them from rusting either way.The bolts thread into the block, so really no antiseize on threads, just a sealant on threads.
You read the tittle , that's why. I read as intake bolts too. As in intake bolts going onto a hole in aluminum headsI don't know why I was thinking intake bolts, but that's what was on my mind. I agree though. I use sealant on every head bolt I install. Blind hole or open. It helps keep them from rusting either way.
Maybe that was it. Thanks. It's usually my stupidity. Maybe we can say this time it wasn't? LOLYou read the tittle , that's why. I read as intake bolts too. As in intake bolts going onto a hole in aluminum heads
Intake Bolts into Aluminum Heads - Sealant or Anti-Seize?
No big deal. We got it covered. lolMy bad then.
Nothing.
I’ve never used anything on intake bolts. No reason to
Red X, I know I haven’t been around these things since the dinosaurs roamed the Earth like you, but it would make sense to give the bolt a little love lube to stop dry holes, which if I’m not mistaken you implied to know everything about…
Me too as a kid. Always wondered why I had puddles of oil on my intake.Nothing.
Thread sealant or rtv or you'll wish you did.No inserts and holes are wet.
