1. K.O. SWINGER
    K.O. SWINGER Meeting in the alley since 1976
    2,806
    2746
    Nov 18, 2010
    oregon
    Local Time:
    11:06 PM
    So I have a chance to buy a weiand xccelerator in good condition it is 225.00 what do you think. I feel it would make a really good stroker intake.?
  2. autoxcuda
    autoxcuda Well-Known Member
    8,227
    2685
    Apr 6, 2007
    Local Time:
    9:06 PM
    Like this one pictured below?:
    Search history here for ones that have sold. Seems to fly under the radar. Don't think I'd pay $225 for one.
    Call Matt a Glendora Dodge Mopar Performance (909) 675-0268 and he has a NOS stash of MP M1 small blocks for $250. Brand NEW !
    Much rather have a brand new M1 with a raised plenum to allow air to cool underneath it.
    I have an M1 on my 416 stroker. Worked great. It's not as aggressive as say a Victor single plane. The M1 has more curved runners. Like that Weiand.
    • Like Like x 1
    • Professor Fate
      Professor Fate Push the button, Max...
      3,783
      5626
      Jan 13, 2020
      Wisconsin
      Local Time:
      11:06 PM
      Kinda depends on your build... Heads? Cam? Gears? Stall speed? It's a single plane, so it's not gonna start building power until a little higher up, say 3-3500 rpm...
      • Like Like x 1
      • K.O. SWINGER
        2,806
        2746
        Nov 18, 2010
        oregon
        Local Time:
        11:06 PM
        Yeah I run an m1 for many many years and is one of my personal favorites the only thing I was considering is the square bore flange. But $250 for a new m1 is a killer deal no getting away from that.
        • Agree Agree x 1
        • K.O. SWINGER
          2,806
          2746
          Nov 18, 2010
          oregon
          Local Time:
          11:06 PM
          Yes this would be for a stroker, I really see no advantage of a dual plane with a 4-in arm there's gobs of torque below 3,500 RPMs and and I personally would not run a dual plane on a stroker.
          • Agree Agree x 1
          • RustyRatRod
            RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
            88,448
            71741
            Jun 7, 2010
            Georgia
            Local Time:
            12:06 AM
            I think a Street Dominator would win out over the Accelerator. By a good bit. It would certainly have a bit more on the bottom and match the Accelerator at least on top. Maybe better. ...and I agree. 225 seems a bit steep, BUT new intakes are either hard to get, you cannot get, or they take forever to get. So I'm sure that affects used intake prices.
          • autoxcuda
            8,227
            2685
            Apr 6, 2007
            Local Time:
            9:06 PM
            Glendora MP had small block ones in stock at a show last week.
            just call and ask for Matt
            • Like Like x 1
            • autoxcuda
              8,227
              2685
              Apr 6, 2007
              Local Time:
              9:06 PM
              The spread bore deal is a minor bummer. But no reason to buy (for your specific combo) an inferior intake that happens to be square bore.
              Like one step forward, but 2 steps back.
              • Agree Agree x 1
              • rumblefish360
                rumblefish360 I have escaped the evil Empire State! FABO Gold Member
                44,150
                16313
                Jun 21, 2005
                Florida
                Local Time:
                12:06 AM
                Spreadbore carb pad is a minor issue fixed through the MP books instructions of danm installation. EZ-PZ nice and easy. Even a Chevy guy can do it.
                • Like Like x 1
                • rumblefish360
                  44,150
                  16313
                  Jun 21, 2005
                  Florida
                  Local Time:
                  12:06 AM
                  For a standard head, the Weiand is way better than the Holley Street Dom. Now the Holley STRIP Dom would be the better of the two.
                  • Like Like x 1
                  • rumblefish360
                    44,150
                    16313
                    Jun 21, 2005
                    Florida
                    Local Time:
                    12:06 AM
                    Like said above, a lot depends on the cam, gear, stall, etc…. Of the engine and what it is designed to do. A dual plane like the RPM is an excellent choice for a mild compression medium sized cam and gear ratio. This would be great in a heavy A body, as in, power everything and A/C along with any other thing that adds weight.
                    If your car is light (under 3300) with a pro street or drag theme, then it’s the single plane which goes great with cams like a duration @050 of 250 and greater, higher stall converters, 4.10 & greater gears.
                    IMO, that Weiand would be very good on relatively stock displacement sized engines. It is a very good intake.
                    • Like Like x 1
                    • autoxcuda
                      8,227
                      2685
                      Apr 6, 2007
                      Local Time:
                      9:06 PM
                      I only have a 236/242 @0.050 with a comp 274-solid
                      416” with ported Edelbrock heads. I have equivalent to 3.55 due to my short 24.5” tires compared to most other running 27” or so.
                      I mentioned switching the M1 single plane for a RPM dual plane I have on the shelf. And the guy that directed motor build said, “DONT YOU TOUCH IT”
                      it runs excellent. Very responsive. Car weighs 3209 lbs.
                      I have stiff suspension, low profile tire, handling shocks… I’m never going to transfer weight on the street.
                      • Like Like x 1
                      • rumblefish360
                        44,150
                        16313
                        Jun 21, 2005
                        Florida
                        Local Time:
                        12:06 AM
                        This is your set up in the “Autocross Cuda” correct?
                      • autoxcuda
                        8,227
                        2685
                        Apr 6, 2007
                        Local Time:
                        9:06 PM
                        Yes, more setup for occasional track days. I drive it on the street and freeway all the time. Weekly or more.
                        It seems to be a good combination, low maintenance, stoplight to stoplight deal for what I do with the car.
                        At the track a new Challenger SRT-8 392 6-speed with headers could not pull side of me on the straightaway (about 70 to 120 mph)
                        Speedo is way off. Only doing 80-85
                        • Like Like x 2
