Interior and dash lights
TheMopars
Active Member
SoCal
So I was giving a friend a ride in the Barracuda (69) and was showing him that the "cigar lighter even works" and when the lighter popped the map light right below it came on. But only the front map light, not the rear courtesy lights. I started trying a couple of things and when I rotate the headlight switch to turn on the interior lights the rear lights come on and front map light shuts off. If I turn the headlights off completely the map light turns off but if the headlight switch is on, either full or parking lights, the map light comes on. The rear lights still function correctly when the doors open and close but the map light doesn't come on with them anymore. And the cluster/dash lights no longer work. I'm going to pull out the wiring diagram to see if I can figure this out but electrical is definitely not my strength lol. Any help is appreciated. I did check the map light bulb to make sure it was seated correctly and seems fine. One clue may be that the cigar lighter doesn't work anymore, I suspect this could be the issue or maybe a grounding problem.
TheMopars
Active Member
SoCal
Check your fuses. They can burn off inside the cap where you can’t see it.
Ding ding ding.... what's that saying.... keep it simple stupid? I was trying to jump ahead without ever checking the box. Finally got a chance to take a look and sure enough, burnt out down at the cap. I guess everything still working but not how it's supposed to work threw me. Also found a 10A fuse in a 20A slot, not the worst crime....
Ironracer
Gearhead
Tampa Bay Florida
Beats a 20 in a 10!!!!
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
IMHO a blone fuse does not cause the symptoms you describe.
Wires melted together, or shorted might
TheMopars
Active Member
SoCal
I was worried about that but replaced the fuse and all is back to normal. Map, courtesy and dash lights all working correctly, dimmer too.
Now that I spent an hour plus looking over the wiring diagram I know how to add the glove box light, now just need to find one!
Mike69cuda
Mopar Moron
Overland Park Kansas
There was a weird thing that happened with these cars we found back in the day. I don’t remember the exact sequence, but it was something like this: turn on the headlights, turn signals, emergency flashers, and step on the brake and the radio would come on.
We did this to listen to the radio in family car without the keys. Strange things can happen when something goes wrong with wiring.
Mattax
Just the facts, ma'am
Phila. Pa
There are some years/models where the wiring arrangement allowed a backfeed of sorts when the right combination was hit. Someone posted something like you mentioned and it made sense when looking at the wiring.
rays266
Ohio USA
depress the brake, push the emergency flasher in til it connects but not on, and turn on the left blinker. Viola, the radio works, no key. ha ha I remember that Why?
Mattax
Phila. Pa
I can't answer the partial push, but the hazard switch is always hot. It also connects to all the turn signals. So basically power is going through the hazzard back to through the turn signal switch to the fuse that's normally only hot with key in run or accessory.
dodgegtdart68
landfall,mn
So I was giving a friend a ride in the Barracuda (69) and was showing him that the "cigar lighter even works" and when the lighter popped the map light right below it came on. But only the front map light, not the rear courtesy lights. I started trying a couple of things and when I rotate the headlight switch to turn on the interior lights the rear lights come on and front map light shuts off. If I turn the headlights off completely the map light turns off but if the headlight switch is on, either full or parking lights, the map light comes on. The rear lights still function correctly when the doors open and close but the map light doesn't come on with them anymore. And the cluster/dash lights no longer work. I'm going to pull out the wiring diagram to see if I can figure this out but electrical is definitely not my strength lol. Any help is appreciated. I did check the map light bulb to make sure it was seated correctly and seems fine. One clue may be that the cigar lighter doesn't work anymore, I suspect this, maybe a grounding problem, could be the issue.
I have a 1968 dodge dart GT , does anyone know what amp fuses and what order they go in
TheMopars
Active Member
SoCal
This is from the 1969 SM, not certain it's the same for 68'
BillGrissom
Sacramento
Yes. Happened to the blower fuse in our 1970 Matador wagon long ago. My dad pulled out the fuse and it looked intact, so put it back and gave up (would be costly), so our family went years without AC in Florida. Finally, a guy at work told him the fuse wire can melt right inside the cap where you can't see it. Does so from heat at the contact due to corrosion, not excessive current draw, which can also melt the plastic fuse holder. He then installed a tiny circuit breaker which will reset and we had AC again. Dad refused to buy tools or fix things correctly, relying on scotch tape and epoxy, which never worked.
