1. mikewadkins
    mikewadkins Active Member
    41
    1
    Apr 11, 2016
    Twin lakes,wi
    Local Time:
    7:05 PM
    My interior lights are driving me crazy. The lights seem to work with door switches. I can open doors they go on close they go off. About hour later i look my lights are on. Open door close door they stay on. Only way to turn off is disconnect battery. Then door switch works again. Then starts all over again. Need help with wire diagram.
  2. AAndrews
    AAndrews Supercuda
    500
    394
    Nov 5, 2014
    St. John's, Newfoundland, Canada
    Local Time:
    9:35 PM
    What year and model of car??
  3. mikewadkins
    41
    1
    Apr 11, 2016
    Twin lakes,wi
    Local Time:
    7:05 PM
    68 barracuda
  4. RedFish
    RedFish Well-Known Member
    23,287
    2161
    Sep 5, 2007
    Local Time:
    7:05 PM
    A delay timer is part of lighting package. That's your problem. The lights are supposed to stay on for a couple minutes with door switch cycle, then go off and stay off until next door switch cycle. timer goes bad lights come back on or just wont go off.
    I can't say exactly where under the dash this little bugger is located.
    • Like Like x 1
    • AAndrews
      AAndrews Supercuda
      500
      394
      Nov 5, 2014
      Local Time:
      9:35 PM
      Ok, try this.
      Remove the door switches, one at a time and disconnect it. Tape up the wire end so it doesn't short out , tie a string around the wire end and drop it into the threaded hole in the A-piller so you can fish it out after. Close the door and see if the lights come back on. This method will eliminate the door switches. A meter will only show you continuity while pushing the plunger into the switch. You may not be pushing the plunger in deep enough when closing the door or it may only be making intermittent contact.
      Second thing is the headlamp switch. It has a setting for turning on the interior lights that may be defective, possibly shorting out somehow.
      Cheers!!
    • AAndrews
      AAndrews Supercuda
      500
      394
      Nov 5, 2014
      Local Time:
      9:35 PM
      Did the 68 Barracuda's come with that delay circuit? I've never seen one.
    • RedFish
      23,287
      2161
      Sep 5, 2007
      Local Time:
      7:05 PM
      Yep, not all but those with this lighting package even had a little light in the top of that plastic ign' switch bezel. My 68 parts car had it but the instrument panel was removed. The timer just laying between ign' switch and ash tray area. It surely mounts in a clip of some sort.
      • Like Like x 1
      • mikewadkins
        41
        1
        Apr 11, 2016
        Twin lakes,wi
        Local Time:
        7:05 PM
        I disconnect both switches and lights stay on.
      • mikewadkins
        41
        1
        Apr 11, 2016
        Twin lakes,wi
        Local Time:
        7:05 PM
        What does it look like? Just strange the light works with doors then after little bit the lights stay on
      • RedFish
        23,287
        2161
        Sep 5, 2007
        Local Time:
        7:05 PM
      • mikewadkins
        41
        1
        Apr 11, 2016
        Twin lakes,wi
        Local Time:
        7:05 PM
      • RedFish
        23,287
        2161
        Sep 5, 2007
        Local Time:
        7:05 PM
        Same part applies up to 86 model, so cheapest source would be a parts yard if you can find it under those dashes.
      • mikewadkins
        41
        1
        Apr 11, 2016
        Twin lakes,wi
        Local Time:
        7:05 PM
        But light turns on and off just fine. No delay goes back on by its self hour later
      • RedFish
        23,287
        2161
        Sep 5, 2007
        Local Time:
        7:05 PM
        I don't need to argue. Other members who have experienced this very same battery killing issue will chime in here. Good luck.
      • mikewadkins
        41
        1
        Apr 11, 2016
        Twin lakes,wi
        Local Time:
        7:05 PM
        Thanks for help it was working fine before i painted car. No delayed light before. Looking for diagram of yellow n pink wire
      • AAndrews
        AAndrews Supercuda
        500
        394
        Nov 5, 2014
        Local Time:
        9:35 PM
        If you didn't have lamp delay before the problem started, that's not the issue.
        Did you have the wiring harness out of the car when you painted it ? Was the car disassembled ?
      • mikewadkins
        41
        1
        Apr 11, 2016
        Twin lakes,wi
        Local Time:
        7:05 PM
        Yes i took wire harness out and fixed wires that were bad. Im confused on why it works then shorts out little later.
      • AAndrews
        AAndrews Supercuda
        500
        394
        Nov 5, 2014
        Local Time:
        9:35 PM
        It happens Mike !
        I'm no expert but have done a lot of repairs and fixes on A-Body harnesses, especially 67-69 Cudas. This is something simple . My guess is that something is not connected properly (you said it yourself.. everything worked before you took it apart). Retrace the way you re-installed the harness and pay particular attention to the pink and yellow circuits. That's what controls the light circuit. I would re-install the door light switches get everything working, close the doors and wait for the lights to come on. Then, remove the fuses one by one until the lights go out. This is the circuit feeding the lights and the one to check carefully. Keep us posted.
      • Mopar-Mitch
        Mopar-Mitch Well-Known Member
        1,023
        968
        Jul 29, 2018
        Kentucky
        Local Time:
        7:05 PM
        Those door jamb switches adjust their self when you close the door. It's a cylinder that slides then when door opens it breaks contact. I've saw these go bad from wear and not keep their position, that sliding cylinder gets loose. I'd look into that if I were you.
      • AAndrews
        AAndrews Supercuda
        500
        394
        Nov 5, 2014
        Local Time:
        9:35 PM
        I was thinking the same thing but Mike said the problem occurred even after removing the switches all together.
        • Agree Agree x 1
        • moparmat2000
          moparmat2000 FABO Gold Member FABO Gold Member
          12,769
          2887
          May 13, 2010
          Grand Tetons
          Local Time:
          7:05 PM
          Same time delay relay on my 88 shelby z w light package. I believe it goes up to 1994. Time delay relay only works ignition swith light. Not dome lamp. You likely have an issue with the headlight switch rheostat, or a door switch shunting to ground. If the door switces use 2 wires with flat spades its a light package setup. If its a single barrel connector switch, the car does not have a light package
          • Agree Agree x 1
          • mikewadkins
            41
            1
            Apr 11, 2016
            Twin lakes,wi
            Local Time:
            7:05 PM
            I pulled the wire harness apart and traced all the wires. Pulled one fuse at time removed both door switches. Touched the light housing in back pannel...click lights go off. Simple wire on housing was grounding out. Lesson learned K.I.S.S now need to clean it all back up. Thanks for help
          • AAndrews
            AAndrews Supercuda
            500
            394
            Nov 5, 2014
            Local Time:
            9:35 PM
            Glad to hear you found the problem. Most of the problems like this where everything worked before taking it apart are usually fixed this way. Ask me how I know LOL!!
