Internal engine coatings?
Mopar Performance Issues
  1. Brandon Weaver
    Brandon Weaver Well-Known Member
    226
    5
    Nov 6, 2013
    Warsaw, Mo
    Local Time:
    11:58 AM
    Does anyone use those fancy coatings, like the anti-friction coatings on the sides of pistols, ceramic on piston tops/combustion chamber, oil shedding coatings, etc.?
    I'm thinking I'll do some sort of ceramic/exhaust coating on my manifolds, maybe trying some different ones on my valves and pistons... Anyone have any opinion on these? Fancy hooplah to steal your money or is there some decent benefits for the money?
    • Like Like x 1
    • stroked340
      stroked340 Well-Known Member
      4,256
      1139
      Jun 14, 2014
      mass.
      Local Time:
      12:58 PM
      This guy can tell you everything there is to know about coatings and he does them,builds some pretty badass motors too..www.hekimianracing.com
    • MidTexCuda
      MidTexCuda Ancient Member
      697
      24
      May 23, 2004
      Deep in the heart of Texas
      Local Time:
      5:58 PM
      From the little searches I have made on YB coating skirts is ok but if your going to coat the tops of the pistons get them hard anodized. Unless you are going big no2, boost or cant tune a strong combo you really dont need the anodize. Skits maybe.
    • tnts72
      tnts72 Well-Known Member
      662
      31
      Jun 18, 2015
      Illinois
      Local Time:
      11:58 AM
      I've seen lifter valley epoxy coatings to help with oil drainback and reshaped super stocker epoxied intake runners but that's about it... Interesting topic
    • 440dartsport
      440dartsport Well-Known Member
      605
      123
      Oct 14, 2010
      Kewaskum, WI
      Local Time:
      11:58 AM
      We are building a 572 right now and everything is being coated. The pistons are hard anodized coated on the ring lands and the tops. The skirts are coated but I can't remember what they are coated with. The wrist pins are also coated along with the main and rod bearings. IMHO coating is only worth the money if it's an all out motor build or if you are pushing the limits with pump gas or a power adder.
    • Killer6
      Killer6 Well-Known Member
      2,253
      679
      Mar 9, 2015
      PA
      Local Time:
      11:58 AM
      The return on investment won't be too good for thermal coating piston crowns,
      chambers,etc. as stated above.Yes they DO what they say,but the improvement may
      not be noticeable depending on the application. I'm always for improving efficiency &
      power output,but there are plenty of more effective per dollar choices in line ahead of
      these coatings. I would however recommend the coatings inside and out on exhaust
      manifolds,drops underhood temps some,and they will look great for a long time on a
      mostly fair weather machine.A customer had the HP mannys on his 440 6-pak 'cuda
      done I believe around 20yrs. ago, and they still look great,just don't get them wet
      when they're hot.They tend to stain or discolor if you do.
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      10,432
      1289
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      11:58 AM
      ..........U may not notice any improvement, but it will give u piece of mind...............kim........
    • CudaChick1968
      CudaChick1968 The Mistress of Metal FABO Gold Member FABO Vendor
      10,709
      3451
      Jan 17, 2005
      Greenfield, Tennessee
      Local Time:
      11:58 AM
      Thermal barrier coatings can be done at home with an air brush and a toaster oven. :-D
      • Like Like x 3
      • oldkimmer
        10,432
        1289
        Nov 11, 2006
        Local Time:
        11:58 AM
        ...........Hey Leanna, please enlighten us..............thanks..................kim.......
      • CudaChick1968
        10,709
        3451
        Jan 17, 2005
        Local Time:
        11:58 AM
        Just Google "dry film lubricant" and "thermal barrier" coatings. I don't do them here but am somewhat familiar with the processes. You can probably even find a How-To video on YouTube.
        If you want to buy some, check out NICIndustries.com.
      • 273
        273 Well-Known Member
        2,836
        638
        May 14, 2012
        Ontario
        Local Time:
        12:58 PM
        They might not do a lot on there own but with the right thermal coatings you can help you run higher CR's
      • crackedback
        crackedback FABO Gold Member FABO Gold Member
        17,998
        2130
        Aug 7, 2005
        92201
        Local Time:
        9:58 AM
        Techline Coatings is another company that has engine coating products.
        • Like Like x 2
        • Brandon Weaver
          226
          5
          Nov 6, 2013
          Warsaw, Mo
          Local Time:
          11:58 AM
          Thanks for digging this back up guys! The reason I asked is I was reading some of David Vizards writing and it seems like he is a HUGE believer in coatings, but it also seems sometimes for product placement...
          Leanna, do you think the thermal coatings would even show an improvement on hyper pistons? Are bake-em-yerself coatings as any a professional would have? (with proper application of course)
          I'm all for anything that'll protect my engine, even a little, by preventing detonation or such, but I'm a little weary of products being a scam.
        • CudaChick1968
          10,709
          3451
          Jan 17, 2005
          Local Time:
          11:58 AM
          I'm DEFINITELY not well versed in this and won't claim to be. I'm only familiar with it through a few hipo articles over the years combined with my powder supplier manufacturing some of the highest-regarded coatings in the automotive industry.
          I encourage all of you to do your own research beyond message boards and get the facts both from reputable people who use it and make it, and learn from them.
        • 273
          2,836
          638
          May 14, 2012
          Ontario
          Local Time:
          12:58 PM
          After the basic 4bbl cam exhaust dollar per return in hp gets less and less except maybe heads. All the little things do add up in dollars and hp.
          But I'd spend $1000 in heads before I'd spend it in coatings
          • Like Like x 1
          • blue missile
            blue missile Well-Known Member
            2,175
            60
            Oct 20, 2008
            Austin Texas
            Local Time:
            11:58 AM
            IMO coatings are more for reliability than power. Lower engine temps, less friction, means less wear.
            Techline is a good supplier and they have a good library of info.
            • Like Like x 1
            • moper
              moper FABO Gold Member FABO Gold Member
              15,488
              1584
              Dec 27, 2004
              eastern CT
              Local Time:
              5:58 PM
              Coatings certainly do have their return on investment. It's up to the guy with the checkbook to determine the sensibility of them. I've been involved with builds that used thermal barrier, oil shedding, and lubricant film coatings. IMO, you get decent return on the thermal and oil shedding. The lubricants are more for "cheap insurance" that another part fails the engine can better survive it.
            • stroked340
              4,256
              1139
              Jun 14, 2014
              mass.
              Local Time:
              12:58 PM
              • Like Like x 1
