Is this a cast or forged crank?
Slant 6 Engines
  1. C2ndLTpigeon
    C2ndLTpigeon Mopar or no Car! FABO Gold Member
    1,018
    735
    May 18, 2019
    Indio California
    Local Time:
    5:22 AM
    Can someone help me id this crank. Almost looks like its steel and makes a good ring when you tap it. But I'm not to familiar with slant cranks. Heres a pic and part number.
  2. clementine
    clementine Flight risk FABO Gold Member
    2,235
    1654
    Jan 3, 2016
    Emerald city
    Local Time:
    5:22 AM
    Isn't there a difference in casting/forge seams to tell?
  3. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    62,973
    29930
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    7:22 AM
    "Is this a cast or forged crank"
    Yes....
    • Agree Agree x 2
    • krazykuda
      62,973
      29930
      Aug 20, 2007
      Orland Park, IL
      Local Time:
      7:22 AM
      Yeah, but he hasn't posted any close-up pictures of the 'parting' line for us to be able tell....
    • Dartswinger70
      Dartswinger70 Awww man...
      4,135
      2464
      Sep 20, 2005
      Southeastern Pa.
      Local Time:
      8:22 AM
      Looks forged if you tap it with a wood handle of a hammer does it have a "ring" to it or a dull "thud" I also think most Slants had forged or should I say they ran a forged crank for a long span of time...
    • C2ndLTpigeon
      1,018
      735
      May 18, 2019
      Indio California
      Local Time:
      5:22 AM
      It has a nice ring unlike some cast V8 cranks I have.
    • Dartswinger70
      4,135
      2464
      Sep 20, 2005
      Southeastern Pa.
      Local Time:
      8:22 AM
      Yeah the ring means forged also the "forge" marks are wide and the cast seam is thin and raised. That looks forged to me but the photo is at a distance. I dont see any thin cast marks in it where they would be. More of a wide flat appearance which would also be forged.
    • C2ndLTpigeon
      1,018
      735
      May 18, 2019
      Indio California
      Local Time:
      5:22 AM
    • Dartswinger70
      4,135
      2464
      Sep 20, 2005
      Southeastern Pa.
      Local Time:
      8:22 AM
      yeah the marks would be out on the throws not on the journals Id zoom that photo out a bit.
      • Like Like x 1
      • C2ndLTpigeon
        1,018
        735
        May 18, 2019
        Indio California
        Local Time:
        5:22 AM
      • Dartswinger70
        4,135
        2464
        Sep 20, 2005
        Southeastern Pa.
        Local Time:
        8:22 AM
        Yeah that pic on the very left, you can make out the "wide" forging mark on the throw. That and the ring and the fact that most slants are forged I'd say its a yes.
        • Agree Agree x 2
        • krazykuda
          62,973
          29930
          Aug 20, 2007
          Orland Park, IL
          Local Time:
          7:22 AM
          Forged...
          • Like Like x 1
          • Agree Agree x 1
          • C2ndLTpigeon
            1,018
            735
            May 18, 2019
            Indio California
            Local Time:
            5:22 AM
            I did not know a lot of slants had forged cranks, you learn something every day. Thanks for the help @Dartswinger70 :thankyou:
            • Thanks! Thanks! x 1
            • MoparMike1974
              MoparMike1974 FABO Gold Member FABO Gold Member
              3,916
              3369
              Jun 16, 2017
              Maryland
              Local Time:
              8:22 AM
              The rounded edges of the counterweights are a good indication its a forged crank. Cast cranks are usually much more squared off at the edges.
              • Agree Agree x 2
              • volaredon
                volaredon Well-Known Member
                1,675
                584
                Feb 28, 2010
                IL
                Local Time:
                7:22 AM
                all slants til mid '76 prod had forged cranks.
                • Agree Agree x 1
                • Valleyant
                  Valleyant Valleyant
                  454
                  49
                  Jul 3, 2009
                  Cincinnati, Oh
                  Local Time:
                  7:22 AM
                  Hey, very easy to check....if the mains measure over an inch wide and the thrust about 1.25 wide then you have a Forging! The cast cranks had smaller mains/thrust.............that looks like a forged crank to me.....forge on!!!!!!!!!!!!!! and Slant 6's RULE !
                  • Agree Agree x 1
                  • 65 Cuda 340
                    65 Cuda 340 FABO Gold Member FABO Gold Member
                    988
                    1425
                    Dec 27, 2019
                    Tallahassee Florida
                    Local Time:
                    8:22 AM
                    Besides the wide forging mark and other things mentioned above, the casting number on the crank would indicate late sixties, which would mean forged crank.
                  • RustyRatRod
                    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                    88,399
                    71659
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    8:22 AM
                    You can easily tell from the very FIRST picture it's a forged steel crank.
                  • Dartswinger70
                    4,135
                    2464
                    Sep 20, 2005
                    Southeastern Pa.
                    Local Time:
                    8:22 AM
                    I think so too, but the point was to get the OP to know how to tell which is why I asked him to zoom the pic. Then I hopefully informed him of what the wider forging marks looked like. I can only hope he understands. I'd post a pic of a cast crank,but right now the only one I have out of an engine is forged.
                    • Like Like x 2
                    • C2ndLTpigeon
                      1,018
                      735
                      May 18, 2019
                      Indio California
                      Local Time:
                      5:22 AM
                      And the info helped. Ive messed around with some 318's and they have all had cast cranks. I just wanted to be sure as I never would of expected there to be more forged cranks in the slants. But yes I do now understand what you meant looking at the marks, like I said I learned something new today.
                      • Like Like x 1
                      • RustyRatRod
                        88,399
                        71659
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        8:22 AM
                        Yeah I get that, but he didn't ask HOW to tell. He asked if WHAT he HAS is forged. It is. But, since we do all want to spread information....at least I know I do, HERE is how you tell.
                        • Thanks! Thanks! x 5
                        • 65 Cuda 340
                          988
                          1425
                          Dec 27, 2019
                          Tallahassee Florida
                          Local Time:
                          8:22 AM
                          Found this pic on line. I believe top is forged, bottom cast. If that is so (and I've never had a cast slant six crank physically in my hands), they do look different, but not in the way cast vs. forged V8 cranks do. Please correct me if the bottom pic is not a cast slant six crank. The pic came from a Hot Rod article on building a hot slant six, and the cast crank was chosen because it was strong enough and a lot lighter.
                          Chrysler Slant Six Cylinder Engine - Mopar Muscle Magazine
                          • Like Like x 1
                          • RustyRatRod
                            88,399
                            71659
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            8:22 AM
                            Both of those appear forged.
                          • Hyper_pak
                            Hyper_pak Old School Chrysler Fan
                            3,995
                            4220
                            Feb 14, 2010
                            Desoto Texas
                            Local Time:
                            7:22 AM
                            Check the number against this chart.
                          • 65 Cuda 340
                            988
                            1425
                            Dec 27, 2019
                            Tallahassee Florida
                            Local Time:
                            8:22 AM
                            OK, I'm gonna stick my neck out and still say the bottom one is cast. Note that the center counterweight is significantly smaller. Also, the rod bearing widths are narrower. I'm not aware of any slant six forged cranks with a smaller center counterweight or smaller rod bearing widths (of course, I have been wrong before). Here's a pic that Dutra posted on Slant Six Org. a few years ago, when he was putting together an aluminum block slant six with a cast crank. Looks to me like the bottom crank above, albeit ground on (lightened) a bit:
                            Another:
