He seems to have lost faith in what he has and a new replacement is cheap enough.It`s just parts, buy em.![]()
The reason I'm reluctant to some degree is I have yet to find evidence that pickups on these distributors are almost nearly flush to the surface of the coil, like how mine shows. If you could show me evidence that they exist then that certainly could let me know that, the replacement pickups these days are made totally different and it sticks out beyond the surface, as opposed to possibly NOS or original remanufactured distributors using high quality parts truly have pickups that look very identical to what I have. I have on hand a new replacement pickup, someone dropped off and it sticks out off the surface around 1mm. I know I keep talking like I'm going against the grain of what y'all are saying, but I'm trying to understand what is normal. I certainly don't have expertise in this sort of thing, but I have no idea what you have seen through your experience working on these type of distributors. When my pickup looks different than everything else I see for this particular distributor, it just makes me question why and I want to understand, that is all.He seems to have lost faith in what he has and a new replacement is cheap enough.
Not my decision to make, or convince you. I'm not in that hunt. I just made a recommendation because you seem to not trust that distributor now. I kinda don't blame you. Lots of good, affordable ones on the market, plus we have a really great member here @halifaxhops who can set you up with a nice distributor specifically curved for your application.The reason I'm reluctant to some degree is I have yet to find evidence that pickups on these distributors are almost nearly flush to the surface of the coil, like how mine shows. If you could show me evidence that they exist then that certainly could let me know that, the replacement pickups these days are made totally different and it sticks out beyond the surface, as opposed to possibly NOS or original remanufactured distributors using high quality parts truly have pickups that look very identical to what I have. I have on hand a new replacement pickup, someone dropped off and it sticks out off the surface around 1mm. I know I keep talking like I'm going against the grain of what y'all are saying, but I'm trying to understand what is normal. I certainly don't have expertise in this sort of thing, but I have no idea what you have seen through your experience working on these type of distributors. When my pickup looks different than everything else I see for this particular distributor, it just makes me question why and I want to understand, that is all.
I agree with all you say here, but the WHY it boogered the rotor up is not being addressed. I'm guessing the plastic collar that holds the shaft from coming up has broken and failed. He said he could not move the shaft side to side, but I never saw where he tried to LIFT the shaft. There should be little play there if any. If the shaft moved up enough to crap the rotor all up, then it's entirely possible the distributor shaft came out of the intermediate shaft. I've seen that happen. The rotor looked suspiciously similar to his.IDK, I would have started with replacing the rotor first, new or used. Their lies your problem to start with. Yes, you could have a bad vacuum advance can but it would not have an effect on engine stumble. As Bewy mentioned several times, the pickup post protruding pass the coil has nothing to do with its operation. The reluctor's teeth do not protruded outward at the same length most of the time. The gap measurement given by the "book" is used to compensate for this flaw
.View attachment 1716519188
This is the meat of the problem, not making a good electrical contact with the center post, the spring riding along the outside of the center post having little to no contact. An easy fix, I for one have bent this spring before, it happens leaning over fenders, pulling on plugs wires, sometimes just not enough room to lift the cap up, but to slide it over. LOL
Unfortunately I did not take a picture of the shaft, but this image is a screenshot from some YouTube video and is the best I can come up with at the moment being away from the car.I agree with all you say here, but the WHY it boogered the rotor up is not being addressed. I'm guessing the plastic collar that holds the shaft from coming up has broken and failed. He said he could not move the shaft side to side, but I never saw where he tried to LIFT the shaft. There should be little play there if any. If the shaft moved up enough to crap the rotor all up, then it's entirely possible the distributor shaft came out of the intermediate shaft. I've seen that happen. The rotor looked suspiciously similar to his.
Good! Then the only other "guess" I have is either the wrong rotor and or cap was used, or the rotor was not put back properly after it was removed.Unfortunately I did not take a picture of the shaft, but this image is a screenshot from some YouTube video and is the best I can come up with at the moment being away from the car.
If I push up on the shaft itself from the bottom, the plastic retaining collar installed at the base, just outside the distributor cast housing, has hardly any tolerance in play, it is not broken or seems damaged or anything.
The majority of vertical play that I see if I pull up on the reluctor is coming from the metal part (the actual name escapes me) that the weights at the bottom are retained in during centrifugal force, that is held in place by the tiny spring clip. The groove cut into the shaft that the spring clip sits in has quite a bit of width when compared to the diameter of the spring clip. This poor drawing I made shows what I'm talking about.
- Green Dot= diameter of spring clip inside the groove.
- Blue = tolerance that the spring clip can travel until it tops out and not allow the metal weight retainer the reluctor installs on from traveling any further.
So, with the tight amount of play from the plastic shaft retainer + the additional amount of play given from the spring clip allowing travel of the metal weight retainer. The reluctor can travel about 2.5 mm if I pull up on it when the distributor is fully assembled.
With this said, would this be too much travel causing the problem where the rotor traveled so much into the cap that it could have bent that spring tab?
I did that to a rotor decades ago. Instead of putting the cap on straight I got it over the distributor and slid it into place. Guessing the center cap button caught the rotor and bent the contact. Rookie mistake!Hello All,
Long story short, I have finally got around to get my '74 Dart Sport 360 back up and running to an extent. The last time I drove it (2022) and parked it in the garage I had a heck of a time keeping the engine going while driving it as it was severely hesitating, stumbling and fall on its face, especially during acceleration. Thinking it was really a carburetor problem (due to not driving it often and possibly bad gas), I got the carburetor tuned up off engine and I'm still seeing and feeling the motor acting like it is misfiring or doing weird things. I pulled the distributor cap off and low and behold it is a mess under the cap. No Earthly idea how, but the rotor contact spring was bent out of shape, hardly touching the button on the cap, blade is severely fouled (had heavy deposit of metal on the tip), the contacts on the cap are really fouled and corroded. Okay simple enough I can replace these easily, BUT my main concern is the ignition pickup. Looking at videos online and pictures of replacement parts these all look to have the magnet sticking out off the coil. Mine on the other hand looks very flat against the coil. I can't honestly say the reluctor looks damaged as if it hit the pickup and sheared it off, because it don't see significant damage to it. The ignition pickup assembly is tightened down and not loose to where it could have slipped into the path of the reluctor.
- Judging by the pictures can you determine if indeed this pickup looks damaged, should it be replaced ?
- What could have really caused the rotor to be so damaged and bent ?
- If rotor was damaged on the spring it would have caused such significant fouling ?
Image taken from Youtube video showing the pickup sticking out...
