What is weird is that the image on Mancini Racing website shows the arm of the cannister looking like the original that came off this distributor but flipped 180 if I orient it the same way as the picture.Oops, misspoke, didn't notice the pic of the pick up. Not sure, maybe Lean Burn?
So in the image on my post #50, the location I called out where the pin inserts for NEW is actually the location if you are using a points distributor? And pin hole location OLD is for electronic ? Or is inner / outter hole creating limits in the advancement of the pickup due to pivot point ? This is the part number I found on the old canister, unfortunately I don't know what second or third number are because they got punched out for the mounting hole... If I'm using the inner pin hole location what is a part number for a replacement i must use for that one ?The one on the left is for a points distributor. B/rb are a mirror image.
