Is This Exhaust Manifold Repairable?
Mopar Exhaust Systems
  1. 3rdLM23P9
    3rdLM23P9 FABO Gold Member FABO Gold Member
    746
    601
    Aug 8, 2012
    Sylvania, Ohio
    Local Time:
    11:04 PM
    I was hearing exhaust leak noise from my 340 GTS. Pulled the driver side manifold and found this. Looks like a repair was attempted before - based on the crack in these photos, does this look repairable?
    Thanks!
  2. Dartswinger70
    Dartswinger70 Catch a wave youll be sittin on top of the world
    3,311
    1765
    Sep 20, 2005
    Southeastern Pa.
    Local Time:
    11:04 PM
    Hard to say id say get input from a welder however if it were me, id figure it was brazed/welded once, and it lasted till this crack why not get a new one. i think they repop em...
    • Agree Agree x 1
    • Cuda416
      Cuda416 FABO Gold Member FABO Gold Member
      2,083
      1654
      Jun 12, 2014
      South, TX
      Local Time:
      9:04 PM
      Repairable, of course, cost effective? Depends on your skillset or your friends.
      • Agree Agree x 6
      • Thanks! Thanks! x 1
      • 3rdLM23P9
        746
        601
        Aug 8, 2012
        Sylvania, Ohio
        Local Time:
        11:04 PM
        I do have another manifold - a repop, but this one I believe is an original one as it has the correct date for the car. I would like to get it fixed if possible. I recall a FABO post long ago in which a member mentioned a welding shop in the Ft. Wayne Indiana area that did great work welding these - just can't recall the name of the outfit.
        Thanks!
        • Like Like x 1
        • Dartswinger70
          3,311
          1765
          Sep 20, 2005
          Southeastern Pa.
          Local Time:
          11:04 PM
          In that case its definitely worth something i wouldnt trash it untill you talk with a cast iron welder. I have heard it can be done.
          • Agree Agree x 2
          • 33IMP
            33IMP Well-Known Member
            1,620
            1689
            Jul 3, 2020
            Taxifornia, soon 2b arizona
            Local Time:
            8:04 PM
            For my 33 straight eight, i would certainly try to have it repaired, cause there is basically no alternative. I know, ive got one that looks like it has been tried to repair about ten times, in ten different places. Lots and lots of cracks
            For yours, you have to decide if originality is worth the effort (which may not be successful) and the expense.
            If i had a repo on the shelf waiting? For me, the answer would be no.
            • Agree Agree x 2
            • MoparMike1974
              MoparMike1974 FABO Gold Member FABO Gold Member
              3,393
              2688
              Jun 16, 2017
              Maryland
              Local Time:
              11:04 PM
              It appears to have been brazed so that would all have to be ground out. You can fix cast iron with brass and it will hold up well.
              The standard fix would be to V out the crack and fill with a nickel rod (they make nickle wire for mig also). Pre-heating the part is a must and a slow cool down is important or it will crack along side of the new weld. We used to cover the part in sand for the cool down process.
              Don't thorw that manifold away. You would have no problem selling it if you decide not to fix it.
              • Agree Agree x 4
              • barbee6043
                barbee6043 barbee 6043 FABO Gold Member
                14,939
                7872
                Jul 20, 2008
                Shepherd, Texas ( SE Tx)
                Local Time:
                10:04 PM
                There are even some high tech specialty rods and like said^^ pre heat and cool down, they even make a special blanket for such.
              • Slantsix64
                Slantsix64 Well-Known Member
                3,156
                1324
                May 11, 2014
                SGV
                Local Time:
                10:04 PM
                Clean it up very good and weld it with some nickle rod.
              • MoparLeo
                MoparLeo NRA BENEFACTOR LEVEL LIFE MEMBER FABO Gold Member
                908
                637
                Feb 10, 2016
                Moreno Valley, Cal. So. Cal.
                Local Time:
                8:04 PM
                Unless you are experienced in doing this type of repair, take it to a professional.
                If you don't you may make a part that was repairable, unrepairable
                They will have the proper equipment and experience.
                • Agree Agree x 4
                • Professor Fate
                  Professor Fate Push the button, Max...
                  2,245
                  2979
                  Jan 13, 2020
                  Wisconsin
                  Local Time:
                  10:04 PM
                  I'd give it a shot- as said, clean out all the old braze repair, preheat and prolong the cooldown. Nickel rod, or Muggyweld makes specialty rods just for this particular type of repair. Or leave it to a professional.
                  I think the real problem is going to be finding a machine shop willing to do a one-off setup and mill/blanchard grind the mating surfaces flat again, it's getting hard to find someone to do piecework anymore.
                  • Agree Agree x 1
                  • 33IMP
                    1,620
                    1689
                    Jul 3, 2020
                    Local Time:
                    8:04 PM
                    Unrepairable is what my manifold looks like. At least ten bad braze repairs, with cracks right next to them . If I grind out the braze, I will have five separate exhaust manifold pieces.
                  • MoparLeo
                    908
                    637
                    Feb 10, 2016
                    Local Time:
                    8:04 PM
                    If is a matter of a functioning exhaust, headers are always available until you figure out what to do with the manifold. Unless this is some very rare, original car good headers may be a good option right now.
                  • Bob Jasinski
                    Bob Jasinski FABO Gold Member FABO Gold Member
                    277
                    119
                    Mar 7, 2019
                    Danville CA
                    Local Time:
                    8:04 PM
                    I've not had success getting a cracked exhaust manifold successfully repaired, even with "experienced" welders, the two I've done both blew out after firing it up the first time. Having written that, I've heard very good things about this company:
                    Metal Stitching & Thread Repair Inserts. - Turlock , CA - LOCK-N-STITCH, Inc
                    I've not personally used them, but would if I had a need. I know they've successfully repaired rare 413 Chrysler crossram 300F/G exhaust manifolds.
                  • MoparMike1974
                    3,393
                    2688
                    Jun 16, 2017
                    Maryland
                    Local Time:
                    11:04 PM
                    I should have noted that someone already drilled a crack stop hole in that but they didnt go out far enough. I can see a crack just passed the hole.
                  • 3rdLM23P9
                    746
                    601
                    Aug 8, 2012
                    Sylvania, Ohio
                    Local Time:
                    11:04 PM
                    Thanks everyone - I will find a "pro" to clean it up and weld it.
                  • toolmanmike
                    toolmanmike Moderator Staff Member FABO Gold Member
                    61,243
                    49716
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    10:04 PM
                    That's pretty ugly. When you hear from your welding shop with an estimate report back here and let us know.
                    • Agree Agree x 2
                    • 3rdLM23P9
                      746
                      601
                      Aug 8, 2012
                      Sylvania, Ohio
                      Local Time:
                      11:04 PM
                      Will do Mike - thanks! It is ugly, and it was pretty loud!
                      • Agree Agree x 1
                      • 3rdLM23P9
                        746
                        601
                        Aug 8, 2012
                        Sylvania, Ohio
                        Local Time:
                        11:04 PM
                        I found the shop I was thinking of: Perkins Repair Service in Fairland, Indiana. Called and chatted with the owner, and texted him the photos for him to review and opine on - will let you know what I hear.
                        • Like Like x 1
                        • 3rdLM23P9
                          746
                          601
                          Aug 8, 2012
                          Sylvania, Ohio
                          Local Time:
                          11:04 PM
                          So, he got back to me quickly and said he can repair - cast iron welding - estimate $150. I think it worth that to keep the original manifold with the car.
                          • Agree Agree x 6
                          • toolmanmike
                            61,243
                            49716
                            Jan 18, 2006
                            Iowa
                            Local Time:
                            10:04 PM
                            Less than I expected. I would pull the trigger on that price I think. Single used manifolds are going for $2-300 each.
                            • Agree Agree x 2
                            • Mark G
                              Mark G Member
                              6
                              2
                              Jun 9, 2017
                              Seattle
                              Local Time:
                              8:04 PM
                              I would be tempted to pull the other one off and see if there are failing repairs or cracks. Get them both done at the same time if needed.
                              • Agree Agree x 1
                              • RustyRatRod
                                RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                                77,746
                                55097
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                11:04 PM
                                Muggy Weld.
                              • Swinger 340
                                Swinger 340 Active Member
                                37
                                24
                                Jun 9, 2021
                                Lake Placid, Florida
                                Local Time:
                                11:04 PM
                                Ugly crack and a difficult repair, due to its stress point of attachment. The leak that I noticed appears to be at the top of the exhaust port. The flange may just need to be milled flat, so not to blow out the gasket.
