Is this normal for the fuel gauge?
Electrical and Ignition
  1. magnumdust
    magnumdust Well-Known Member
    2,780
    53
    Apr 14, 2011
    cali
    Local Time:
    4:46 AM
    I've found that after i disconnect my battery & reconnect it, my gas gauge stops for working for a few hours. Then it seems to just start working again.
    Is this normal?
    Its kind of an annoyance as I disconnect my battery at the end of my weekend to save it from draining.
  2. jerry6
    jerry6 Banned
    2,442
    47
    Aug 29, 2010
    Mon
    Local Time:
    5:46 AM
    Not normal , at least not on my car . Lose wire /contact ?
  3. cudamark
    cudamark Well-Known Member
    6,227
    37
    Mar 14, 2009
    San Diego
    Local Time:
    2:46 AM
    Not normal for anything I've ever owned. What year and model is it? What happens if you ground the fuel sender wire while it's acting up?
  4. RedFish
    RedFish Well-Known Member
    23,554
    2318
    Sep 5, 2007
    Local Time:
    5:46 AM
    Its probably loose at its connections to the printed circuit board. Factory used stamp tin speedy nuts there. a little vibration or temp change will make or break the connection.
    Depending on what panel you have and your ability you might reach up in there with a 1/4 drive disc ratchet and 3/8 socket to tighten the nuts a little.
    Any way you go about it disconnect the neg' battery cable first.
  5. kt340sport
    kt340sport Well-Known Member
    1,732
    18
    Dec 23, 2006
    Miramichi N.B Canada
    Local Time:
    4:46 AM
    Your battery shoud never drain , if it does either the battery is bad or there is something left on to drain it , i can leave my dart for three weeks and it will turn over with lots of power. As far as the fuel gauge sounds like a bad ground at the tank .
  6. 67Dart273
    67Dart273 Well-Known Member
    40,297
    7953
    Oct 14, 2010
    Idaho
    Local Time:
    2:46 AM
    Not normal. Does the temp gauge do the same thing?'
    FIRST order of business is to FIND THE DRAIN
    Take a test lamp and hook in series with the disconnected battery ground. Remove fuses one at a time and see if the drain goes away. If not, disconnect the alternator output stud and see if that kills it.
  7. magnumdust
    2,780
    53
    Apr 14, 2011
    cali
    Local Time:
    4:46 AM
    The temp gauge seems to always work.
    I'll try that w/ the test lamp tomorrow if i can.
  8. magnumdust
    2,780
    53
    Apr 14, 2011
    cali
    Local Time:
    4:46 AM
    I'm positive its not the battery. Once in awhile i'll forget to unhook the cables and then 2-3 weeks later my battery will have gone bad and the parts store will swap it out.
  9. jerry6
    jerry6 Banned
    2,442
    47
    Aug 29, 2010
    Mon
    Local Time:
    5:46 AM
    Do you have an alarm on the car ? I let my car sit for a month at times starts right up . You must have something hooked up pulling power when key is off
