dvboth
Top picture the pressure plate is unbolted from flywheel, bottom picture it is bolted to the flywheel, my question is should the fingers drop that much?
With it in the car like that the adjusting rod is fully adjusted to the end of the rod, and the clutch engages right off the floor!
Grease is from the throw-out bearing cause it is constantly riding on the fingers!
