Isky Rocker Arms
Big Block A body Tech
  1. baracus
    baracus Well-Known Member
    499
    111
    Jul 19, 2010
    ga
    Local Time:
    7:44 AM
    So my machinist is helping me put my 383 short block together, while on vacation last week he calls me and tells me my rocker arms are bad, says the pads are too 20160605_190107.jpeg 20160605_190146.jpeg worn. I'm using old isky ductile iron rocker arms. I have heard these were bulletproof and have found 2 sets locally. i just got back in town and haven't been to the shop yet but I took some photos of the other set I have at home, these are in the same shape as my other set. You can see the pads are worn, would these be unusable? Can the pads be machined to match or any other way to make these work? I've never used a solid cam before and have no experience with adjustable valvetrain. What do you guys think? If these are trash, Ive been looking for a good quality adjustable roller rocker, what have you heard about the Mancini Racing rollers? Good price, aluminum rocker arms, good on the street? Stock stroke 383 for street/strip, hughes solid cam mid 550 lift, 238/243. Thanks.
  2. davescuda
    davescuda FABO Gold Member FABO Gold Member
    10,242
    1643
    Apr 30, 2007
    Cheshire, CT
    Local Time:
    7:44 AM
    You should be able to machine them. they do not look that bad.
    • Agree Agree x 2
    • Thanks! Thanks! x 1
    • RustyRatRod
      RustyRatRod Lemmie see your b00bs. FABO Gold Member
      67,780
      42084
      Jun 7, 2010
      Georgia
      Local Time:
      7:44 AM
      I would run those so quick AS IS and never look back.
      • Agree Agree x 2
      • Like Like x 1
      • yellow rose
        yellow rose Overnight Sensation FABO Gold Member
        27,246
        23466
        Jun 19, 2015
        Central Washington
        Local Time:
        4:44 AM
        I'm with RRR. You can surface them. Or you can send them to Rocker Arm Speciaties, or what the new name is but they can repair all that stuff.
        Those things are pretty much billet proof.
        • SGBARRACUDA
          SGBARRACUDA ROY FABO Gold Member
          18,575
          7163
          Dec 7, 2006
          PLANT CITY FL. and PERRY GA.
          Local Time:
          7:44 AM
          I years past I have run the 273 adjustable rockers on more than a few 340'S that had much more wear than that without an issue. If they were worn to bad, I would file them smooth again. Not only was money tight but there wasn't a whole lot of people making roller rockers for Mopars. We ran what we could afford.
          • Agree Agree x 1
          • ssba
            ssba Well-Known Member
            2,293
            352
            Dec 29, 2009
            rensselaer in
            Local Time:
            6:44 AM
            Look them over for wear from bad oiling. Scoring on the bottom of rocker shaft.
            Also dress and align pad to valve stem carefully with shims.
            The assemblys can be rebuilt easy enough but should be done to the specific head. At least that's how I like to use them.
            • Like Like x 1
            • hangn0ut
              hangn0ut Well-Known Member
              747
              120
              Dec 3, 2012
              rialto.ca.
              Local Time:
              4:44 AM
              What is the new name of rocker arm specialties?
            • RustyRatRod
              67,780
              42084
              Jun 7, 2010
              Georgia
              Local Time:
              7:44 AM
              Here you go, sir.
              Rocker Arms Unlimited
            • txstang84
              txstang84 Well-Known Member
              4,496
              452
              Oct 10, 2011
              Abilene, TX
              Local Time:
              2:44 AM
              Did he elaborate as to what measurements are making them unserviceable?
            • baracus
              499
              111
              Jul 19, 2010
              ga
              Local Time:
              7:44 AM
              No, he didn't specify why exactly. I'm going to stop by tomorrow after work and see.
            • RustyRatRod
              67,780
              42084
              Jun 7, 2010
              Georgia
              Local Time:
              7:44 AM
              Those pads are thick. They can even be dressed with a file if done carefully. It's not rocket science.
              • Like Like x 1
              • txstang84
                4,496
                452
                Oct 10, 2011
                Abilene, TX
                Local Time:
                2:44 AM
                I think I'm showing my cynicism...but I've been hosed by machinists and shop owners in the past...
              • hangn0ut
                747
                120
                Dec 3, 2012
                rialto.ca.
                Local Time:
                4:44 AM
              • Abodybomber
                Abodybomber Breaking street machines , since 1983.....:) Legendary Member
                31,576
                10471
                May 21, 2011
                Arroyo grande ca
                Local Time:
                4:44 AM
                This...Thanks for the link,on R.A.S.Rob!
                • Like Like x 1
                • famous bob
                  famous bob mopar misfit
                  18,386
                  7751
                  Aug 14, 2011
                  okla
                  Local Time:
                  6:44 AM
                  if they are smooth, I`d run them, they ain`t wore out .
                • yellow rose
                  27,246
                  23466
                  Jun 19, 2015
                  Central Washington
                  Local Time:
                  4:44 AM
                  Yup, that's it. I knew them by the original name and can never remember the new one.
                  I sent them my Norris SS W5 rockers and they put needle bearings between the rockers. Made the engine turn over much nicer and stopped the galling issue I had.
                • Cranky
                  Cranky Banned and proud
                  205
                  85
                  Nov 25, 2009
                  Pasadena, TX
                  Local Time:
                  6:44 AM
                  @baracus I know this is an old thread but what did you end up doing with this?
                • SuperStock426
                  SuperStock426 FABO Gold Member FABO Gold Member
                  327
                  199
                  May 20, 2020
                  Fort Oglethorpe Georgia
                  Local Time:
                  7:44 AM
                  This is what I'm using in the 440 in my Demon..They're installed on Indy aluminum heads and work just fine....Mine are 1.6 ratio..
                • 1968rt
                  1968rt Well-Known Member
                  45
                  62
                  Jan 2, 2008
                  Local Time:
                  7:44 AM
                  I had a Black and Decker valve machine years ago and it had the provision to grind rockers. Did many sets. came out like new.
                  • Like Like x 3
                  • Cranky
                    205
                    85
                    Nov 25, 2009
                    Pasadena, TX
                    Local Time:
                    6:44 AM
                    I have a B&D machine CAT # 282/550 Type T.....
                  • Krooser
                    Krooser Reform School Graduate
                    2,852
                    2350
                    Jul 19, 2015
                    Central Wisconsin
                    Local Time:
                    6:44 AM
                    Find someone with the rocker arm attachment on their valve grinder...B&D, Souix and others had them.
                    Ship them out if need be...
                    • Like Like x 1
