James’ 1974 W200 build
Okay. Power steering cooler bracket made and mounted. Just gotta plumb it all in.
Well it works. The temperature of the fluid before adding the cooler was 160-180 degrees. You could not touch any part of the metal lines. Now the lines are just warm to the touch, I was recording about 100 degrees after adding the cooler.
