dustoff440
Due to the hood not fitting with the thermoquad adapter filter set up I Will be going with a 650 double pumper for now and need jet and power valve recommendations. Please don't tell me I need a bigger carb. this is all I have right now.
360 mag stock with a 500 cam and 286 duration should idle with at least 10 hg
air gap knock off
stock magnum heads
bone stock 650 dp holley
3.91 sure grip on 24 inch tires
3000 converter
MSD with dialed in MP DIzzy
Stock 340 exhaust with sidepipes
air gap knock off
stock magnum heads
3000 converter
