Just bought a chrysler lebaron
Mopar General Discussions
  1. ike61
    ike61 Well-Known Member
    557
    178
    Sep 6, 2010
    minnesota
    Local Time:
    11:23 PM
    Howdy all. Just picked up this beauty for $300. I know very little about these cars and was looking for advice on trouble areas, maintenance, inexpensive worthwhile mods, etc. My plans are to make the car mechanically good and drive it on nice days and let the kids drive it around. Here is some background:
    86 chrysler lebaron, 2.2 turbo, auto trans, rust free, new tires and battery, brand new head replaced 10k miles ago, 90k miles. The top works fine, but has some tears. Probably not worth replacing the top. What trans would this have? Any good? Advice? comments? Thanks
    • Like Like x 4
    • diymirage
      diymirage HP@idle > hondaHP@redline
      22,193
      17873
      Oct 12, 2012
      michigan
      Local Time:
      12:23 AM
      man, its still in the shipping crate
      i love it
      • Like Like x 6
      • Agree Agree x 4
      • dartfreak75
        dartfreak75 Restore it, Dont part it! FABO Gold Member
        9,493
        7053
        Aug 10, 2011
        Virginia
        Local Time:
        12:23 AM
        Those are cool cars I always wanted the turbo shadow they had. I think it was the same engine that was I the lebaron. I had a plain 1992 shadow I loved that car. I wish I still had it
        • Like Like x 1
        • diymirage
          22,193
          17873
          Oct 12, 2012
          michigan
          Local Time:
          12:23 AM
          speaking of power upgrades
          • Thanks! Thanks! x 1
          • Tooljunkie
            Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
            17,209
            17607
            Jul 22, 2017
            Manitoba
            Local Time:
            11:23 PM
            I had an 86 gts. 2.2 turbo. Its old, look into replacing the oil feed line to turbo. I replaced mine with a coiled brake line.
            check your engine oil as well, it must be turbo approved or it will coke up in the turbo. Turns black fast too.
            I was running diesel oil in mine. It seemed to like it.
            Had an issue with heat going away on acceleration, turns out line for water valve and egr got swapped. Air bleed by thermostat,if you replace coolant make sure you get all the air out when you refill it.
            Check your timing belt too.
            The reluctor below the rotor can come loose, a short screw will solve it. Its picky, early multi point injection was prone to this problem. Also the pickup wiring was prone to failure.
            thats all i got, it was 20 plus years ago when i had it. Was a good car.
            • 318willrun
              318willrun Utube channel 318willrun
              16,142
              17798
              Sep 13, 2013
              I'm here
              Local Time:
              11:23 PM
              I used to run those mopar turbo cars. Just a blast. One trip to the pet store and for 3 bucks I could knock a full second of the E.T. slip. We ran the MP computers that was located behind the passenger kick panel. Brings the factory boost from 7 to 11 psi. Those motors are TOUGH. Head gasket and timing belt are the weak links. After driving it, or racing it, let it idle about 30 seconds. That cools off the turbo.
              • Agree Agree x 3
              • diymirage
                22,193
                17873
                Oct 12, 2012
                michigan
                Local Time:
                12:23 AM
                this?
                • 318willrun
                  16,142
                  17798
                  Sep 13, 2013
                  I'm here
                  Local Time:
                  11:23 PM
                  yep, fish tank bubbler. We usually started with a MP computer for 125 bucks. With the MP computer and the fish tank bubbler we could run 14 psi without ever a cut out. Modify the air box and exhaust and go fox body hunting :D
                  • Like Like x 2
                  • Agree Agree x 1
                  • Biff
                    Biff Cheep not easy
                    6,793
                    13939
                    Jan 30, 2017
                    Canada
                    Local Time:
                    9:23 PM
                    Yup still have my 1989 Daytona 2.2 turbo 2 , steel crank, roller cam all factory .
                    • Like Like x 4
                    • diymirage
                      22,193
                      17873
                      Oct 12, 2012
                      michigan
                      Local Time:
                      12:23 AM
                      cool
                      i did the same thing in my 1.8T passat...before i had it reflashed to hold a stead 17 pounds
                      • Like Like x 1
                      • moparmat2000
                        moparmat2000 FABO Gold Member FABO Gold Member
                        18,040
                        7003
                        May 13, 2010
                        Grand Tetons
                        Local Time:
                        11:23 PM
                        Change the fuel feed and return lines from the firewall to the fuel rail. Use high burst pressure fuel injection rated hose, and fuel injection style smooth hose clamps. I have seen these hoses develop pinhole leaks and hose a hot engine down with a fine spray of fuel and burn the car down. Seen plenty of these in the salvage yards with the front end burnt off because of this.
                        • Like Like x 1
                        • billccm
                          billccm Well-Known Member
                          153
                          114
                          May 13, 2018
                          Tucson
                          Local Time:
                          10:23 PM
                          I've owned two Shelby Chargers, a Shelby Lancer, and a LeBaron Convertible. Love the 2.2l turbo and miss those cars. In fact, I have been shopping craigslist for another LeBaron convertible, although I want a 1991, or so.
                          Advice? The 2.2l turbo loves head gaskets. If Mopar Performance still makes them order several spares now and get new stretch bolts, too. I got to the point that with the assistance of three helpers I could do a 'lift and replace' head gasket swap in one hour flat.
                          AIS motors like to fail, but just locate the rivets to wire connections and solder flow for the fix. Single board computers fail due to molex connection on the PCB. MAP sensors throw codes due to poor connections; get some DeOxIt and spray every connector in sight often!
                          These cars have idiosyncrasies; accept this fact and be handy with a wrench and you will have a blast. If you are looking for Honda reliability walk away now.
                          • Agree Agree x 2
                          • robert flippo
                            robert flippo Well-Known Member
                            253
                            179
                            May 9, 2018
                            gibson station va
                            Local Time:
                            12:23 AM
                            I have a 1986 Turismo,,only torque converter that will work on labaron,k cars,chargers,omni,horizon is an 86 or 87 model.,,anything before 86 was 3 bolt torque converter, 88 and up has a lockup converter for overdrive.,,One problem you may run into, some 86 and 87 was mechanical fuel pump, some was electronic, on the electronic, the pump is in the gas tank, when i put the 89 motor in, had problem locating fuel pump assembly, finally found out a 1987 dodge omni had what i needed.
                            • 67Dart273
                              67Dart273 FABO Gold Member FABO Gold Member
                              46,675
                              14575
                              Oct 14, 2010
                              Idaho
                              Local Time:
                              9:23 PM
                              That's Jon Voight's car!!! LOLOL
                              • Like Like x 1
                              • harrisonm
                                harrisonm Well-Known Member
                                2,960
                                2969
                                Jan 16, 2005
                                Topeka, KS
                                Local Time:
                                5:23 AM
                                I bought a new 88 LeBaron Convertible 2.2 turbo and drove it for about 13 years. It's one of those cars that I am STILL kicking myself in the ass for selling. It was a GREAT cat.
                                • Agree Agree x 1
                                • billccm
                                  153
                                  114
                                  May 13, 2018
                                  Tucson
                                  Local Time:
                                  10:23 PM
                                  I drove my 91 lebaron convertible 21 years and 174k miles. It had the best "convertibities" of any convertible I've ever owned. Replaced it with a 2012 mustang convertible, but miss ye ol'lebaron and starting to look for a cream puff.
                                • Joey4speed
                                  Joey4speed FABO Gold Member FABO Gold Member
                                  1,177
                                  877
                                  Jul 17, 2018
                                  Jersey
                                  Local Time:
                                  12:23 AM
                                  That brings back memories.
                                  Those 2.2s rumbled so bad the steering wheel vibrated.
                                  I had a K Car with one, for some reason it kept blowing the distributor pick up.
                                • cawcislo
                                  cawcislo Well-Known Member
                                  338
                                  217
                                  Aug 7, 2018
                                  Ontario, Canada
                                  Local Time:
                                  12:23 AM
                                  I’ve got a 91 Shelby Daytona sitting in the garage. Www.turbodidge.com. Lots of good info. Also try www.thedodgegarage.com. Lots of dodges in there and good info on turbo 2.2/2.5 you’ll learn lots. Have fun.
                                  • Agree Agree x 1
                                  • Heywodja
                                    Heywodja The Heartbeat Stops Here. FABO Gold Member
                                    624
                                    284
                                    Aug 16, 2014
                                    Texas
                                    Local Time:
                                    11:23 PM
                                    I had the glh and glhs back in the 80's and today I still have a caliber srt 4 in the garage.. IMG_0808.JPG
                                    • Like Like x 2
                                    • Keith Mopar
                                      Keith Mopar Mopar Nut
                                      3,072
                                      1476
                                      May 15, 2005
                                      Calgary AB.
                                      Local Time:
                                      10:23 PM
                                      Love that Lebaron and I also love those old Turbo motors.
                                      I had quit a few of them over the years and even put a 2.5 turbo in an old 2.6 mitsu mini van and had a blast. Still have my turbo shadow.
                                      • Like Like x 1
                                      • Kendog 170
                                        Kendog 170 Let the boy go !
                                        1,681
                                        1110
                                        Mar 10, 2016
                                        Tewksbury Ma.
                                        Local Time:
                                        12:23 AM
                                        My buddy put a Conquest Turbo motor and trans. in a Plymouth Arrow. Car was pretty quick.
                                      • moparmat2000
                                        18,040
                                        7003
                                        May 13, 2010
                                        Grand Tetons
                                        Local Time:
                                        11:23 PM
                                        I still have an 88 daytona shelby in the corner of my shop piled high with boxes. I was going to get to it someday, but at least it's out of the elements and safely hidden inside. I also have an 87 lebaton turbo coupe with full digital dash and overhead console parked beside my house. Needs a headgasket. I had put some money in this thing. Would sell it for $800 if anybody wants it. Rust free solid texas car.
                                      • Tooljunkie
                                        17,209
                                        17607
                                        Jul 22, 2017
                                        Manitoba
                                        Local Time:
                                        11:23 PM
                                        I never mentioned, guess im getting my mom’s dodge shadow, 140,000 km’s on it. Needs a paint job but solid from end to end.
                                        • Like Like x 1
                                        • Daves69
                                          Daves69 Well-Known Member
                                          5,327
                                          3568
                                          Feb 20, 2011
                                          WestOfChi
                                          Local Time:
                                          11:23 PM
                                          Plane, Trains, & Automobiles.....
                                          • Like Like x 1
                                          • sireland67
                                            sireland67 FABO Gold Member FABO Gold Member
                                            9,467
                                            3688
                                            Oct 27, 2010
                                            WV
                                            Local Time:
                                            12:23 AM
                                            Replace the heater control valve, they are prone to cracking.
                                            When they break it will dump all the coolant out of the engine.
                                            • ike61
                                              557
                                              178
                                              Sep 6, 2010
                                              minnesota
                                              Local Time:
                                              11:23 PM
                                              Thanks a lot everybody. Appreciate the feedback. Anything on the transmission?
