Just bought a chrysler lebaron
Mopar General Discussions
  1. VOETOM
    VOETOM Well-Known Member
    899
    336
    Jul 27, 2008
    KC, MO area
    Local Time:
    1:07 AM
    Here was mine. 1984 600 with TII parts. Stock 84 head and cam, stock TII turbochrger and stock injectors. With about 12 PSI boost it ran 13.6s at 100.
    • Like Like x 4
    • pishta
      pishta I know I'm right....
      17,585
      7165
      Oct 13, 2004
      Tustin, CA
      Local Time:
      11:07 PM
      Mom had one. IIRC it was a 600 too but not turbo. I ran it through a 6" deep puddle at about 30 and the muffler pulled right off the crimped pipe. Was very reliable and tight, although it only had 30K on it at the time. I remember the doors were massive for its size. .
      • Like Like x 1
      • billccm
        billccm Well-Known Member
        127
        95
        May 13, 2018
        Tucson
        Local Time:
        11:07 PM
        It does not have the problematic A604 (nicknamed a sick oh four). It's a bulletproof A413 I believe. Should last quite a while.
        Go over to allpar.com and register for the eek forum (every extended K). You will get lots of knowledge there.
        • Thanks! Thanks! x 1
        • VOETOM
          899
          336
          Jul 27, 2008
          KC, MO area
          Local Time:
          1:07 AM
          I ran a rare TII auto in mine. Long story how I got it but it had al the good things in it. I swapped the transfer gears to get a 3.22 final drive ratio instead of the stock 3.02:1. Mine had the stronger axles and HD carrier bearing assembly. Like Billcom said, it was truly bulletproof but I never did anything crazy with high boost or exceptionally high load high stall starts. I miss the car but rust took it out.
          • pt70
            pt70 Well-Known Member
            365
            275
            Aug 23, 2019
            CT
            Local Time:
            2:07 AM
            If it has a 3 speed automatic it has a good tranny in it. Drop the trans pan, adjust the bands, change the filter, and add ATF+4 fluid ONLY. About 4 - 5 quarts.
            • Agree Agree x 1
            • ike61
              ike61 Well-Known Member
              489
              79
              Sep 6, 2010
              minnesota
              Local Time:
              1:07 AM
              Im new to this. What does that do?
            • 318willrun
              318willrun Utube channel 318willrun
              14,876
              15650
              Sep 13, 2013
              I'm here
              Local Time:
              1:07 AM
              If you put a "T" in the vacuum hose that goes to the waste gate, then put another vacuum hose on the T running someplace where you can adjust the boost by opening the bleed-off on the bubbler. Thing is, you have to be careful because boost without fuel is very bad. That is why I used the MP computer, it brought the boost from 7 lbs factory to 11 lbs, and ensure enough fuel that we ran a 180 thermostat and 14 lbs of boost all day never hurt anything. We did this to a few turbo cars, never hurt anything.
              • 66340SEDAN
                66340SEDAN FABO Member #3649 FABO Gold Member
                25,656
                23400
                Nov 20, 2006
                Minnesota
                Local Time:
                1:07 AM
                I had this kid over 20 years, only drove it 1 of those years and decided to sell it...got bored with it and wanted the extra space so I sold it. 1989 CSX-VNT, 500 made, mine was one of 232 that came with the recaro seats, car was mostly complete and even had extra fiberride wheels and a NOS front air dam. I’m sure I’ll miss it some day, car hauled ass....175 HP, it was a 15k new and had many “firsts” in the industry.
                • barbee6043
                  barbee6043 barbee 6043 FABO Gold Member
                  12,622
                  5255
                  Jul 20, 2008
                  Shepherd, Texas ( SE Tx)
                  Local Time:
                  1:07 AM
                  Youngest daughter went out and found one of these beasts while in HS about '92 or 03, it was one its second engine at that time. She drove the wheels off it and put probably 300,000 mi on it! It was a vert, woreout. Her mom (my X) sells it for her to a "family friend"> Funny part of the story s this friend approaches me to buy it as it is a "rare colletible". He said he paid $1000 for it and just wanted to get his money back! This was back about '99.
                • ike61
                  489
                  79
                  Sep 6, 2010
                  minnesota
                  Local Time:
                  1:07 AM
                  Sweet. The ultimate sleeper
                • coffeedart67
                  coffeedart67 Well-Known Member
                  1,196
                  59
                  May 9, 2010
                  Southeast South Dakota
                  Local Time:
                  1:07 AM
                  2.2s don't like to be overheated. I had a 86 Shelby Charger that I raced circle track. Originally turbo but put 86 HO carburated 2.2 in it. I put a Daytona radiator in it. Never overheated even when I ran a whole feature and forgot to turn on the fan.
                • ike61
                  489
                  79
                  Sep 6, 2010
                  minnesota
                  Local Time:
                  1:07 AM
                  . Thats one unique ride. Thanks for sharing
                • 66 Valiant wagon
                  66 Valiant wagon Well-Known Member
                  155
                  128
                  Jun 16, 2019
                  Minneapolis, MN
                  Local Time:
                  1:07 AM
                  When I was in HS in the late 80's my Boss at the local fast food place I worked at had that exact same style Lebaron with the wood grain siding and a convertible. She was so proud of that car. I can't help wonder if its the same car.
                • ike61
                  489
                  79
                  Sep 6, 2010
                  minnesota
                  Local Time:
                  1:07 AM
                  Probably not. Mine is originally from nevada. Probably why it is rust free
