I got this K member with some parts for a 1969 Barracuda. Although I believe it is the correct width for an A Body, the underside is cut out for the sway bar to pass through. I think the mounts are located for a small block. It has a coin, but it is welded well off center. I cannot find any numbers on it so far. Any idea what this is K member might have been on originally?
