Can anyone help me with finding a after market k member for a 1975 Dodge Dart?
I’m going to be putting a built 400 bb in the car it was originally a slant 6 car and shumacher is taking forever to get the conversion mounts I need in so I figured it would be best to just upgrade my k member? And I seen this but didn’t see my year listed. Will it still work for my 1975 dartJust curious, something wrong with the factory one? Asking for an "aftermarket" k-frame is a little vague. What's the car going to be used for? budget, options required etc?
I agree if funds are not in question..RMS suspension. Better than the QA1, and I've run both setups.
1st off I hear you about Schumacher I to have been waiting for their products since April..I’m going to be putting a built 400 bb in the car it was originally a slant 6 car and shumacher is taking forever to get the conversion mounts I need in so I figured it would be best to just upgrade my k member? And I seen this but didn’t see my year listed. Will it still work for my 1975 dart
Do you have a link to the website?RMS suspension. Better than the QA1, and I've run both setups.
Thanks man that really helps out a lot. But yes the factory k member is still in great conditionNever actually answered.. yes, that would work. K-frames are interchangeable from 67 on up.
Looking at that one posted again, that one does not use spool mounts. So, it will fit but you'd need mounts. Possibly the schumaker ones?
HDK on this site.
Don't wait for Schumacher. They are apparently having some problems and have slowed or stopped production.1st off I hear you about Schumacher I to have been waiting for their products since April..
You still have to source conversion mounts but pre 73 is a lot easier
I have a 73 swinger I called summit racing to verify everything would work with a magnum engine so giving a big block is no problem
Everything from your stock setup should bolt right up to the qa1
I myself might be buying one of these for my ride depending on how it handles with the original K member I have its bent up a little bit
Wow this looks like an awesome dealYou should read the customer testimonials on the HDK site. That's what sold me.
HDK Suspension Customer Testimonials
I hadn’t looked there
