Kickdown ID
seabee
1537 Paper Street
Hi Gang,
I've got this kickdown that I believe goes with a SB 1974 E-Body but not sure. Any of you Mopar Jedi Masters have an idea?
Pretty sure those are truck pieces. Trucks and vans are the only ones that have enough room for that 1-piece trans rod. Cars use a Z arrangement.
If you need a 4bbl kickdown assembly your best bet by far is to pick up the Lokar kit. It has a lot more adjustability and it'll still be cheaper than buying it from a parts hoarder who has a few sets sitting on top of one of the pair of Hemi heads.
Thanks Tyler. This kickdown came with a bunch of stuff I recently bought so just trying to figure what it is.
I have the Lokar set and it is nice!
It will work anywhere it will fit.
I had one of those set-ups on a 74 Chasrger with a 360 4bbl. It will work ok, you just have to make the adjustment down at the trans end instead.
