Kickdown linkage question #3 w/video
Transmission and Drivetrain Tech
  1. Tad
    Tad Well-Known Member
    466
    374
    Jun 19, 2018
    Not here
    Local Time:
    5:09 AM
    39E22765-C886-4D57-9BD6-88940726F1B7.jpeg AF028629-49FF-451D-8990-263A2516CB9E.jpeg 7EF76795-D8D8-4849-9ACE-43D4E1CB91D5.jpeg Finally got linkage adjusted and in the right space. I can’t seem to get full throttle on the carburetor when it’s hooked up. The kickdown linkage doesn’t move far enough back to allow full throttle at the carburetor.
    • Like Like x 1
    • Garrett Ellison
      Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
      3,788
      3009
      Jan 1, 2018
      Southwest VA
      Local Time:
      8:09 AM
      I'm thinking you'll have to adapt to a complete later type kick down assembly to use the ThermoQuad.
      • Like Like x 1
      • Tad
        466
        374
        Jun 19, 2018
        Not here
        Local Time:
        5:09 AM
        Were you the one who mentioned using a police car style kick down system?
        • Like Like x 1
        • Garrett Ellison
          3,788
          3009
          Jan 1, 2018
          Southwest VA
          Local Time:
          8:09 AM
          No it wasn't me but I would bet money that's going to be your best bet!
        • Oldmanmopar
          Oldmanmopar Going left turning right FABO Gold Member
          9,486
          6375
          Jan 8, 2009
          Danielsville Pa. 18038
          Local Time:
          8:09 AM
          Police car? that was me Here it is and I just grabbed another set up on Face book market place. This 318 4bbl out of a diplomat police car was just on face book for sale. So they are still out there. I paid $100 for everything and it had a fresh trans. The linkage was worth more than I paid for the motor and trans
          • Like Like x 1
          • Demonic
            Demonic Well-Known Member
            1,620
            1301
            Mar 21, 2015
            Maryland
            Local Time:
            8:09 AM
            Was it a set that went with that powertrain? If anyone ever pulled the motor and trans together - the one piece rods often get bent. Carefully, slowly "tighten" a bend to get a shorter overall rod. OR - If the throttle pressure is working correctly - cut the slot longer.
          • Oldmanmopar
            9,486
            6375
            Jan 8, 2009
            Local Time:
            8:09 AM
            You will never get a one piece system to work on an A-body. 71 on up B and E body or C-body will take a one piece. No A-bodies or pre 71 B's. There is not enough firewall clearance.
            • Agree Agree x 2
            • Sedanman
              Sedanman 67-9 Valiant specialist
              8,508
              613
              Apr 3, 2009
              chicago Il
              Local Time:
              7:09 AM
              looks like your missing the tension spring for that slider arm
              • Like Like x 1
              • Tad
                466
                374
                Jun 19, 2018
                Not here
                Local Time:
                5:09 AM
                Thank you for everyone’s reply. Haven’t gotten it completely set up yet so haven’t put the springs on yet.
              • MOA
                MOA Well-Known Member
                350
                157
                Feb 23, 2016
                CA
                Local Time:
                7:09 AM
                I'm modifying my kick down linkage from a 2bbl set up, adding 2 inches to the rod. How far from the back of the slot is the tab for the spring? And where do I find/buy the right spring?
                Thanks
