KIlled my 904
Gearhed73
So.Cal
Was out in mexico doing some 0-60 type stuff, just messing around. After 3rd pass trans started making a slight grinding/rotating sound.. coming from forward section. I was able to move it under very light throttle,every gear the same. Reverse did little better for a minute. Im thinking the input shaft may have broke?
Info on car
69 crew cab valiant
mild 318, loose converter. 8.8 3:73s with traction lock and drag radials.
I can foot brake to 2700rpm, and the hammer it and it dead hooks. Ive been beating on it for a 3 months with current setup.
Need to minimize down time. Where are some good places to work with on a replacement 904?
Gotta pull it either way so you have lots to keep you busy beside an internet forum. Let us know what you find.
When my crappy tci converter let go it sounded awful and started pulling the rpms down in gear.
I"m going to try and get it pulled pretty quick. Im running a Boss Hogg converter
