knock sensor/gauge
Forced Induction Mopar
  1. 70wayfarer
    70wayfarer FABO Gold Member FABO Gold Member
    414
    18
    Jul 20, 2011
    new zealand
    Local Time:
    2:58 PM
    hi..
    anyone using these? are they worth using.
    i'm pushing 10 psi into my 360 via a vortech v2. have just had afr's sorted on the dyno where the dude thinks that a knock gauge might be worth the while installing.
    cheers
  2. 67Dart273
    67Dart273 Well-Known Member
    40,291
    7947
    Oct 14, 2010
    Idaho
    Local Time:
    5:58 PM
    They HAVE to be if they work correctly. Google around, there's guys hooking up sensors to headphones so that they can HEAR spark knock during tuning
  3. 70wayfarer
    414
    18
    Jul 20, 2011
    new zealand
    Local Time:
    2:58 PM
    i was looking at a visual type so as to keep things in check while at the track or just cruising around
  4. HOTMOPR
    HOTMOPR Mr Horsepower
    837
    149
    Feb 8, 2009
    Rochester, wa
    Local Time:
    5:58 PM
    What is that car in your avatar? Looks like a dart camino.. looks cool!
  5. discharger1332
    discharger1332 Well-Known Member
    1,620
    45
    Jan 25, 2010
    silverdale wa.
    Local Time:
    5:58 PM
    valiant ute.
  6. 70wayfarer
    414
    18
    Jul 20, 2011
    new zealand
    Local Time:
    2:58 PM
    yip...1970 Chrysler Wayfarer Utility.
  7. 72BBSwinger
    72BBSwinger Well-Known Member
    2,045
    56
    Feb 23, 2011
    nebraska
    Local Time:
    7:58 PM
    Would be a great thing if it works and exists.
  8. HOTMOPR
    837
    149
    Feb 8, 2009
    Rochester, wa
    Local Time:
    5:58 PM
    my dad has a knock sensor on his turbo 6. It only activates a small LED on the dash when it knocks.
  9. SSVDP
    SSVDP FABO Gold Member FABO Gold Member
    4,599
    4848
    Feb 6, 2009
    Clarksville, Tn
    Local Time:
    8:58 PM
    I haven't looked at this in about 10 years.
    A knock sensor isn't a bad idea but its the implemtation that counts.
    Typically the sensor is tuned in to a certain noise frequency, the problem is if your engine has something that rattles (resonates) at the same frequency then you get a false read.
    So it all come down to how much you want to trust it with your engine.
  10. william
    william Well-Known Member
    174
    11
    Aug 13, 2009
    Ottawa
    Local Time:
    7:58 PM
  11. Map63Vette
    Map63Vette Well-Known Member
    1,522
    25
    Apr 19, 2010
    Lawrence, KS
    Local Time:
    7:58 PM
    Yeah, there are different kinds of sensors. The most basic are essentially just microphones (piezoelectric elements for the engineers out there). They produce a voltage when they are vibrated, so you can more or less just attach them to headphones or a scope. The amount of voltage they produce is based on the severity of vibration, so they'll have lots of electrical "noise" all the time and then spike under conditions like knock (or hitting a hammer on the engine block as a way to test them). I believe Dodge uses the tuned variety mentioned above. I think they operate in a similar fashion (produce a voltage based on vibration strength), but I believe they filter out a lot of the "noise" and only really respond on larger signals. Typically I'm fairly sure they are engine specific though, so they are sensitive at whatever frequency the engineers determined the engine knocks at. This would mean you couldn't necessarily just go out and buy a sensor and expect it to work.
    The more simple "microphone" type are usually just a single wire hookup and I believe are farily common to GM. I know the sensors on my 5.7 Hemi are a two wire variety, but I still haven't figured out how to test them.
  12. MoparDreamin
    MoparDreamin Well-Known Member
    172
    0
    Dec 23, 2009
    firey pit
    Local Time:
    5:58 PM
    The J and S unit is a fantastic knockbox. I have one in my rice burner. It works so well because I have a factory knock sensor. The problem with using it in a motor without a factory sensor is getting the right sensor in the right location to get clean signal. I just order knocksenseMS that has a filter which is frequency tuned for my 318's bore. I plan on just datalogging with it. We'll see if it works. My setup is a 318 magnum with vortech V2 @ 15psi.
    http://www.jandssafeguard.com/
    http://www.viatrack.ca/
  13. 70wayfarer
    414
    18
    Jul 20, 2011
    new zealand
    Local Time:
    2:58 PM
    at the end of the day i dicided on a Innovate Motorsport digital AFR guage. cheers
  14. MoparDreamin
    172
    0
    Dec 23, 2009
    firey pit
    Local Time:
    5:58 PM
    That doesn't monitor knock though....
  15. 70wayfarer
    414
    18
    Jul 20, 2011
    new zealand
    Local Time:
    2:58 PM
    afr's were sorted on dyno and the way i see it if they are all good then the chance of knock/detonation is lessoned. the Innovate Motorsport MTX-L guage i fitted is digital with a digital needle around perimiter of gauge. easy to see and accurate.
