SS23MOPAR
Vintage Kwik Way Piston / Cylindrical grinder. This came from a starter/generator repair shop. I have run the machine and it works fine other than the grinder motor will need brushes and the nut that holds the stone is missing. The coolant pump does not work. It has a stone dresser and a tool holder attachment. The table feeds back and forth without issue. The tailstock can be offset to grind on a taper. What you see is what I have. VERY HEAVY! Asking $1000.00 picked up in Va. -- possible trade for Mopar - Snap on / Mac tools. Machine can sit on work table so will sell without pedestal.
