[WANTED] LA oil pump pickup for special oil pump cover with NPT entry.
Bighead440
Milledgeville, Georgia
I am looking for a static oil pump pickup to be used with the Direct Connection or Milodon special pump cover that has direct entry to the gears, not via the side of the pump (must plug that stock entry point). I have the cover and I want to use a rear sump fabbed pan that has no pickup, so I'll have to mock the depth and adjust the pipe length for clearance to the bottom. Milodon and others have 90* big block static NPT pickups but to simplify things (no elbow fittings), I'd like an inline screen. Thanks for any clues as to where to find one, new or good used!
Make your own, that way it fits perfect. That's what I do, the base's are hard to find but if you got one don't let it go, make it work.
Is this the pickup your looking for?
