[WANTED] LA oil-thru thrust plate bolt, oil slinger, gallery plugs
smokinnjokin
Nekoosa, WI
Gentlemen,
For my small block (360), Looking for the special cam thrust plate bolt with the hole through it to drip oil on the timing tab. I also need the oil slinger that mounts in front of the crank sprocket, and the two oil gallery plugs that go behind the cam thrust plate. Figured it was worth a try on here before I hit ebay.
Thanks,
Andrew
