gregpurcell
Greg Purcell
I sold one set already and I have one more!
This is a set of 11 inch rear backing plates with the separator struts and parking brake arms. Located in Savannah, GA.
This setup will work on most big bolt pattern 8 3/4 rears including A body IF you are using aftermarket axles.(They will NOT work if you have stock A body SBP axles that were redrilled to LBP)
This setup will also work on Dana, 91/4 and many 81/4 axles. $100 shipped in the US
