[Found!] LCA's with tabs pre 73
CL3406
BC
Hello, I am looking for a pair of LCA's with tabs in decent shape. Send a PM if you have some. Thanks.
I'll dig some out of the shed tomorrow. I have another set on a scrap 340 Swinger but I'd like to keep that one mobile.
Sure sounds good. As long as they are not dented up I am interested. I don't mind blasting,painting & changing the bushings. Usual for 50 year old parts..
I believe I have a set. Not sure what they came off of.
FYI
Randys.
Your's are 73-76 LCA's. with the sway bar mount tab in that location on the arm.
65-72 LCA's with the tab, are welded on low, at the end of the arm, by the ball joint stud location.
Thanks for the info.
